  3. Design hierarchy in Encounter
  • Subscribers 92
  • Views 17444
Aram Shahinyan
Aram Shahinyan over 12 years ago
Dear Friends,
I have a block with the same structure (sub module) repeating many times. I have done manual placement & routing for one slice
and saved a design.
Now I need to instantiate and use a hand made slice many times (just like instantiating in layout editor)
Any ideas how I can do that?
Thanks in Advance,
Aram
  • Kari
    Kari over 12 years ago
    you should create a LEF for your block, then that LEF can be loaded at the next level of the design and placed like any block.
  • Aram Shahinyan
     Hi Kari,
    Thank You. Yes, that's one of the ways. Actually I'm doing the design in block level, so I would skip splitting one
    block to many LEFs. Is there any other way? I've read there's partitioning and master/clone technique, but I haven't figured
    out how to do master/clone. I would appreciate if you can walk me through some steps
    Thank You,
    Aram
  • Kari
    if your top-level netlist has this block's module instantiated several times, then once instance will be the master partition and the rest will be the clones. then you just design this block once (like you already have) and it is repeated at the top-level. As for the actual partitioning process and assigning the master, please check the EDI User Guide (See the chapter called "Partitioning the Design" and the section called "Specifying Multiple Instantiated Partitions and Blackboxes".)
  • Aram Shahinyan
    BTW, another issue here is that Encounter does not accept verilog netlists that have same cell instantiated more than once and asks to uniquify netlist with uniquifyNetlist utility. After that procedure extra modules are being generated (module_name_SPC1, module_name_SPC2, etc..) and unique cells are getting instantiated. Please let me know if explanation is not clear.
    My point is in this case names for the same module become different, and how master/clone can be recognized?
  • Kari
    It's been a while since I did this, but it might be that you don't uniquify the netlist if you are doing the master/clone flow. EDI should still accept the netlist, you may have warnings... if EDI really isn't accepting the netlist, then post back the exact error message and we'll see if we can figure out what's going on.
  • Aram Shahinyan
    Hi Kari,
    2 issues when not using unique netlist
     Issue 1  Optimization is limited with non unique netlist
    **WARN: (ENCECO-560):   Netlist is not unique. Cell "array_col_slice" is a multi-instantiated cell. Uniquify your netlist to avoid the problem.
    **WARN: (ENCECO-560):   Netlist is not unique. Cell "mux_out" is a multi-instantiated cell. Uniquify your netlist to avoid the problem.
    **WARN: (ENCOPT-3213):  Netlist is not uniquified -- Some optimization is limited!
     Issue 2 Clock tree synthesis does not work with non unique netlist
    <clockDesign CMD> specifyClockTree -file Clock.ctstch
    Checking spec file integrity...
    Module WPREDecoderPerPort is multiply-instantiated in WDecoderPerPort and another module.
    **ERROR: (ENCCK-404):   Your netlist is not unique. CTS requires a unique netlist before it can run clock tree synthesis. Please load a unique netlist into EDI before you run CTS.
    Aram
