  3. Dummy Pins short errors IO corner pads
  • Subscribers 94
  • Views 16435
amythpai
amythpai over 13 years ago
I donot have much Experience in Place and route operation. The problem is that I have completed the place and routing of the core area as well as the IO pads. When I run DRC verify geometry I have no violations in the core  area but in the Corner IO pads I get two short erros ( LeftBottom and Top right corner pads) in the dummy cell pins. It looks strange because even other two corners have the same dummy Pins but there are no short errors. The two Violations I am getting are
SHORT: Pin of Cell io_pad_left_bottom_corner & Blockage of Cell fillperi_S_0  ( M3 )
Bounds : ( 112.000, 1.900 ) ( 112.000, 2.100 )
SHORT: Pin of Cell io_pad_right_top_corner & Blockage of Cell fillperi_N_78  ( M3 )
Bounds : ( 1568.200, 1503.300 ) ( 1568.200, 1503.500 )
Can anyone please advise me on how to fix it.?
  • Kari
    Kari over 13 years ago
    can you post a picture of the violation? it's likely false, but hard to tell without a picture.
  • amythpai
  • Kari
    my guess is that your IO filler cells don't have the pwr/gnd rails continued through them in the LEF (they layout should be fine). so we get this "violation" of the pwr/gnd pin in the corner cell when it touches the blockage of the filler cell. if your signoff DRC runs clean in this area, then you can ignore these in verifyGeometry.
