  3. Clock Tree Synthesis Through Narrow Corridors
  • Subscribers 95
  • Views 15095
dfick
dfick over 13 years ago
 I'm running clock tree synthesis on a large memory-like array structure where there are narrow corridors between some of the rows/columns. EDI CTS is having a hard time and is creating many buffers in the middle of the design, with huge congestion. Is there anything in particular that I should be looking at for this scenario?
  • dfick
     The working solution is to insert explicit buffers in the clock tree in the netlist. When CTS is called, it creates a subtree for each buffer that is in the tree already. By inserting a buffer for each corridor (that drives the cells in the corridor), CTS was able to run quickly with a good result.
     Full disclosure: I had a sub-module for each corridor already, and a fence for that submodule which kept its cells in that corridor. I added the clock buffer to the input of the sub-modules.
  • fitz
    fitz over 13 years ago
    Obstruction's are another  <DESIGN>.ctstch  option worth trying..............
    AutoCTSRootPin ................
    Obstruction    YES
    CellObstruction
    + ST_SPHS_SLRH_16384x39m16B4_bTR0P Entire
    + ST_SPREG_LRH_4096x36m8B2_bTR Entire
    + ST_DPHS_SLRH_4096x32m8B2_T0P Entire
    + ST_ROM_R_16384x32m32B4_Tol Entire
    + ARM_hard_core Entire
    END
     Shawn
