  3. Inputs without external driver/transition
  • Subscribers 95
  • Views 5442
Kabal
Kabal over 12 years ago
Here is how I defined constraints for example for my inputs:
 # set input ports transition slew rates
set_input_transition -rise -min 0.5 /designs/refleks_switcher/ports_in/pwm_in_port1*
set_input_transition -fall -min 0.5 /designs/refleks_switcher/ports_in/pwm_in_port1*
# set external driver input slew (in picoseconds)
set_attribute external_driver_input_slew {100 100} /designs/refleks_switcher/ports_in/pwm_in_port1*
However, when I run:
report timing -lint
it still shows the same amount of ports with "inputs without external driver/transistion" warning,
why is RTL Compiler not happy with the constraints I defined? I did define the transition
  • Kabal
    ok nevermind I had to use external_driver attribute and I made one of the BUFFERS from library to pretend driving my input pins of top module.
  • Kari
    Kari over 12 years ago
    check into set_driving_cell. that is what i usually see used.
  • asif123
    asif123 over 5 years ago in reply to Kabal
    could you elaborate on how you did it with an example since iam facing the exact issue.
