  3. How to detect the clock glitch ?
  • Subscribers 94
  • Views 16382
phoenixson
phoenixson over 12 years ago
Hi,All
Now , there are two clock signal in the design, the two clocks and select signal are synchronous, but the phase between them is uncertain, then use the selecting signal 'SEL' to switch the two clock dynamically. So it is possible that some glitch will occur, I want to know how to detect or check the glitch in encouter timing system intead of functional verification ?
just like this :
CLK_MUX = SEL ? CLK_0 : CLK_1;
 Thank You.
  • phoenixson
    Does anyone know this ? In the design , it 's a potential problem, so I want to find the solution out.
