  3. CPF style with analog hard macro
  • Subscribers 95
  • Views 17093
GabrielB
GabrielB over 11 years ago
Dear all,
hopefully I'm not writing in the wrong forum - but I saw most CPF related posts are here.
I'm designing a mixed signal ASIC with digital-on-top methodology. I have only one big analog custom hard block, for which I generated the abstract view and wrote by hand a liberty file. My problems arise, since this block needs 6 power supply voltages and 4 grounds. All this voltages together with all analog signals are directly connected to pads. All the digital ports of the block belongs to a single 3.3V power domain.
I'm writing in CPF 2.0 so I can use the set_analog_ports command and the set_macro_model with set_instance -model.
Now: should I define 6 different power domains for my macro and therefore also in my top design?
I tried defining only one 3.3V power domain, but then what about all the power and ground ports?
Thanks in advance
Gabriel
PS: I'm working with conformal 14.10.220, RC 14.11.000 and EDI 14.13
  • fitz
    fitz over 11 years ago
    Gabriel:
    I would concentrate on writing your analog wrapper and power pad connections EXACTLY the way you intend to implement your design.
    Analog analog_inst \
    (.avdd_apin (avdd_anet), . avdd_bpin (avdd_bnet), . avdd_cpin (avdd_cnet] \
    (.agnd_apin (agnd_anet), . agnd_bpin (agnd_bnet) \
    Bump avdd_abump (.bump_pin (avdd_anet));
    The digital vdd and gnd are typically implied in a gate level netlist and are connected by EDI applyGlobalNets.
    The digital side is where the power of CPF comes into play , it allows you to deviate from a homogenous digital power plane.
    Low power techniques like voltage islands etc. were a complete bear to layout and verify before CPF automated this process.
    Shawn
  • GabrielB
    Hi Shawn!
    Thank you very much for your reply! I noticed, that I forgot to mention (really sorry about that!), that my analog hard block is both connected to a big 1.8V digital core and some small 3.3V modules: the hard block has more than 1300 pins, some of which then need level shifting - and I didn't want to instantiate explicitly the level shifter, that's why I'm working with the CPF.
    What you wrote, is exactly what I get confused with, since it is to me not very clear how to treat the (explicit) power ports of my macro.
    I managed in the meanwhile to get a working flow, but I still have doubts, here one of them for example:
    1) the analog hard block has power ports h_VDD33D, h_VDD18D and a common ground for both h_VSSD.
    2) the top level (chip) has top_VDD33D, top_VDD18D and top_VSSD, which connect directly to h_VDD33D, h_VDD18D and h_VSSD.
    3) the digital core has two power domains (PD18 and PD33), also powered by top_VDD18D and top_VSSD, and top_VDD33D and top_VSSD respectively - this information is correctly defined in the CPF.
    4) since the hard block is connected to both top_VDD33D and top_VDD18D I defined inside set_macro_model also two power domains for the macro.
    Now, in the macro definition: what about the ports h_VDD33D, h_VDD18D and h_VSSD?
    If I associate them to a power domain, for example like this:
    create_power_domain -name h_PD33 -boundary_ports {h_VDD33D....}
    create_power_domain -name h_PD18 -boundary_ports {h_VDD18D}
    I don't know where to put the h_VSSD, since it "belongs" both power domains. I tried to put h_VSSD in one of them and I get level shifters between top_VDD18D and h_VDD33D!!
    If I don't say anything about h_VDD33D, h_VDD18D, h_VSSD in the macro definition I get a CLP error since every port has to be either boundary port, feedthrough, analog or floating.
    So the stable solution I found, which gives no errors, but does not look very elegant is to define all the power and ground ports (pins) of my hard block as floating and set them as -primary_power and -primary_ground of the respective power domain: what do you think about it?
    Gabriel
