  3. How to place IO pins on internal wires and bumps in Innovus...
  • Subscribers 95
  • Views 22884
How to place IO pins on internal wires and bumps in Innovus?
fieldy
fieldy over 9 years ago
Hi All,
I'm currently using Innovus to implement a full chip design that has flip chip bumps and has IO pad rings  on the periphery.
I would like to place IO pins of signals and power/ground directly on the bumps but struggling to find a good method to do so.
I can't seem to find anything in the userguide to help me with this. I tried editPin but it will only allow pins to be on the side edges, which is not what I want.
I tried commands to move pins but it also won't let me move pins inside the die area, only letting me move pins to the edges.
Is there a good way to do this?
  • MikeLW
    MikeLW over 9 years ago
    editPin does seem to be mostly geared towards placing pins along the edges, but I think you can do what you want with -assign x y. Have you tried that?
  • fieldy
    Yes, I tried that but all it would do is place the the pin on the outer edges of the chip, ignoring one of x or y coordinates. This seems like a very fundamental procedure that should be possible to do, so I'm hoping there's a simple way to do this which I haven't found yet.
  • Kari
    Kari over 9 years ago
    It's been a while since I've done this, but I don't think you need to use editPin at all. Once you use assignSigToBump to assign a bump to a signal, then the little yellow triangle should appear on top of the bump.
  • mishrak
    mishrak over 9 years ago
    You can place IO pins inside block by using editPin -side inside option.
