  3. LVS Calibre check fail
  • Subscribers 94
  • Views 21548
nhanle
nhanle over 9 years ago
Hi all,
I ran a design use EDI, and there is no short violations when checking with EDI tool.
But, when checking LVS by Calibre, there are many Discrepancy in LVS report. A part of report is below:
Error: Different numbers of nets (see below).
Error: Different numbers of instances (see below).
Error: Connectivity errors.
Error: Instances of different types or subtypes were matched.
Error: Property errors.
Warning: Ambiguity points were found and resolved arbitrarily.
LAYOUT CELL NAME: pzqcal_fsm
SOURCE CELL NAME: pzqcal_fsm
INITIAL NUMBERS OF OBJECTS
                          Layout             Source           Component Type
Ports:               126                  126
Nets:                 6608               6601 *
Instances:        7180               7180 MN (4 pins)
                           7222               7222 MP (4 pins)
Total Inst:         14402              14402
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:    126     126
Nets:     3187  3149 *
Instances: 541   340 * MN (4 pins)
                  397    259 * MP (4 pins)
                    123  140 * SPDW_2_1 (4 pins)
                    2      3* SPDW_2_1_1 (5 pins)
                   5        5 SPDW_2_2 (5 pins)
I check detailed report, and see there is no short violations (internal/external cell), I also include label for pin, power/ground, and also add filler cell/tap cell for desgin.
The Discrepancy include instances, net. For example:
Discrepancy #59 in pzqcal_fsm
X3/X343/M5(11.630,31.795) MP(pch_mac)                    XU19677/MM5 MP(pch_mac)
g: X3/348        g: n_342
d: X3/449        ** no similar net **
b: X3/449        ** no similar net **
** X3/388 **        d: n_500
** VDD **        b: VDD
I tried 3 days, but no results :(. Could you help me, please ?
  • Kari
    Kari over 9 years ago
    This is very difficult to debug without knowing anything about the design. Did you run verifyConnectivity in EDI? You said you had no shorts, but that is a verifyGeometry check. You need to make sure you also have no opens.
  • nhanle
    Thanks Kari, I knew problem. My design overlap VDD and VSS in floorplan :)
