  3. ccopt ignore sink - common ui
  • Subscribers 95
  • Views 5473
Yemelya
Yemelya over 9 years ago
I am looking for a way to remove several sink points from the list of CCOPT leafs, to make sure it will not build the clock tree to these pins.
Thanks and regards,
Boris
  • Kari
    Kari over 8 years ago
    I'm sure there is a way. Look in the documentation for "exclude" or "exclude pin".
  • HDar
    HDar over 8 years ago
    You might wanna look at "ignore pin" too. By excluding the pins, the tool will not consider the leaf pins for skew balancing and clock drc fixing.
    Whereas, by using "ignore pin" on them, they would be considered for drc fixing, but not for skew balancing.
