  3. How do I generate full GDS using Encounter 2014 and osu_soc_v2...
  • Subscribers 94
  • Views 15023
How do I generate full GDS using Encounter 2014 and osu_soc_v2.7 libraries?
Ncsim User 1
Ncsim User 1 over 8 years ago
Hi there,
I am self studying some place & route with Encounter 14. My background are design and synthesis.
The library I use is from this directory.
https://vlsiarch.ecen.okstate.edu/flows/MOSIS_SCMOS/osu_soc_v2.7/cadence/lib/
I managed to load netlist and LEF, create power ring, rail and stripes, place and route. The GDS I export doesn't contain the poly layers.
I suppose it's caused by the LEF file is abstract module which only contains the metal layers. I dont have virtusso to use.
Is it possible and how do I create a full gds with every layers out of Encounter alone?
  • Kari
    Kari over 8 years ago
    when exporting GDS, you merge in the gds files of the std cells, which should have come with the library delivery.
    streamOut -merge {listOfGdsFiles}
