  3. WARN MESSAGE: (IMPESI-3014): The RC network is incomplete...
  • Subscribers 95
  • Views 17305
WARN MESSAGE: (IMPESI-3014): The RC network is incomplete for
Andrea Spiezia
Andrea Spiezia over 8 years ago
I'm running a postCTS hold fix with INNOVUS 17.15, and I've some warning message like the following:
WARN: (IMPESI-3014): The RC network is incomplete for net xxx ....
Do you have an idea about why the tool can't extract the parasitic for that nets?
Thanks a lot.
  • Chetan B S
    Chetan B S over 8 years ago
    Hello Andrea,
    Are you getting these messages during the hold fixing iteration? If you run "timeDesign -postCTS" on the DB, do you see similar messages?
    If it is seen during hold fixing step it could be due to optimization removing and/or optimizing some cells causing net delay to be not computed. However, if you see this in postCTS or postRoute step, we surely need to check for details.
    Chetan B S
  • Andrea Spiezia
    Andrea Spiezia over 8 years ago in reply to Chetan B S
    Hi Chetan,
    yes it's durine postCTS hold fix. Do you mean that the tool have an "old' version of netslist before the fixing, and try to extract a "gost" net?
  • Chetan B S
    Chetan B S over 8 years ago in reply to Andrea Spiezia
    Hi Andrea,
    If these messages are seen during initial iterations in optDesign, it should be fine. However, post all optimization, if you do a timeDesign and see these messages, we should investigate.
    Chetan B S
