  3. constraints file
  • Subscribers 95
  • Views 17960
constraints file
Rahila
Rahila over 7 years ago
Could any one please help me how to find the post layout delay of a  full adder circuit?
I am working with digital cadence and when i try to get the post layout delay, the report is shown as  "NO CONSTRAINED TIMING PATHS FOUND"
  • Edouardfr
    Edouardfr over 7 years ago
    1- Which command are you using?
    2- Is this specific path constrained in your SDC file?
    3- Did you try to use the -unconstrained option in your report_timing command?
  • Rahila
    Rahila over 7 years ago in reply to Edouardfr
    im using the command report_timing to generate the post layout delay report... but the message is as i said..
    even the synthesis timing report says that  the design is unconstrained. since the design donot have a clk signal, what should be included in the constraints file?
    i didnt use the unconstrained  option in the command report_timing... could you please share how to use it?
  • Edouardfr
    Edouardfr over 7 years ago in reply to Rahila
    During synthesis, you can sue some commands like: set_max_delay , to constraint the delay between your input and outputs.
    For STA, try using the command: report_timing -unconstrained
  • Rahila
    ok sir.
    thank you.
