  3. Direction of VDD/VSS (inout vs input)
  • Subscribers 94
  • Views 7412
drdanmc
drdanmc over 6 years ago
What is the reason that power/ground ports that are added in the physical implementation flow have direction "inout" instead of "input"?  Is there a way to force them to be "input" instead without running some post-processing code?
a simple example is starting with something like this out of synthesis:
module mycell(A, Y);
    input A;
    output Y;
    INVX1 myinst(.A (A), .Y (Y));
endmodule
Then using things like this in the physical place/route:
set init_pwr_net "VDD"
set init_gnd_net "VSS"
globalNetConnect VSS -type pgpin -pin VSS -all
globalNetConnect VDD -type pgpin -pin VDD -all
and ending up with
module mycell(A, Y, VDD, VSS);
    input A;
    output Y;
    inout VDD;  // WHY INOUT
    inout VSS;  // WHY INOUT
    INVX1 myinst(.A (A), .Y (Y), .VDD(VDD), .VSS(VSS));
endmodule
The reason I care is in mixed signal sims (AMS) or even DMS sims, I want to avoid any possibility of bi-directional connect modules whenever possible.  To that end, I'd like to be able to simulate the post-physical design (that includes power/ground) but with those defined as "input" instead of "inout".
  • Dimo M
    Dimo M over 5 years ago
    you can use the switch saveNetlist -derivePGPortDir (CUI: write_netlist -derive_pg_port_dir) to enable Innovus to derive the direction of implicitly created power ports.
    Innovus will trace the connectivity and decide the direction of these ports.
    The port direction will be input if the module contains only sinks (loads).
    What constitutes a source and sink is decided based on UPF (if present) and liberty files.
    Dimo
