  3. what's the "FTerm" mean(IMPSYC-1265)?
  • Subscribers 95
  • Views 2913
Goddard
Goddard over 3 years ago
The commands I have used are as follows:
%addNet -power AVSS
%dbGet top.nets.name AVSS
AVSS
%assignPGbumps -nets AVSS -selected
WARN(IMPSYC-1265): FTerm was not found for net "AVSS" ,AVSS has been created.
I dont understand the meaning of FTerm and (IMPSYC-1265)?
I would be very grateful if someone who  could advise me.
  • RamesNaikBhukya
    RamesNaikBhukya over 3 years ago
    Hello Goddard,
    The message "WARN(IMPSYC-1265): FTerm was not found for net VSS" is an Innovus warning message that is triggered when the net VSS does not have a floorplan terminal (FTerm) associated with it. This is usually caused by a net not having any pins connected to it. To fix the problem, you need to identify the net VSS and make sure that it has at least one pin connected to it. After that, the FTerm should be automatically assigned and the warning message should no longer appear.
    Hope this will be helpful.
  • Goddard
    Goddard over 3 years ago in reply to RamesNaikBhukya
    Thanks for your prompt reply
    But I didn't show the command in its entirety may have caused misunderstanding,I update the commands as follows:
    %addNet -power AVSS
    AVSS
    %attachTerm PLL AVSS AVSS
    I can see through Design Browser that the PLL/AVSS pin is connected to the net "AVSS"
    There will still be the above warning, could you please give further guidance according to this situation?
  • DimoM
    DimoM over 3 years ago
    what fTerm means is explained with examples here: Differences between and usage of term,fterm,inst,cell,hinst. .
    Now, this warning seems to have informative character to me.
    The way I understand it is that your top block did not have a fTerm for this net, so the tool created it.
    You can try to create a port explicitly to see if the warning still pops up:
    addNet -power AVSS
    addModulePort ""  AVSS input
    BR
    Dimo
  • Goddard
    Goddard over 3 years ago in reply to DimoM
    Thanks a lot for your reply, and its very helpful to read your recommended post.
    About port I will reply you after following the suggestion.
