  3. No buffers added in power domain, hold violation
  • Subscribers 96
  • Views 10819
Krippkrupp
Krippkrupp over 3 years ago
I have specified two power domains, PD_CORE and PD_ACC. PD_CORE is the default and seems to work fine.
However, the second power domain, PD_ACC, causes some issues. PD_ACC is defined to a certain area, thus causing PD_ACC to have the attribute fence.
I have specified libraries for both domains, however when running CTS, I notice that no buffers or inverters are placed in this domain.
This leads to hold violations in PD_ACC, that can't be fixed since no buffers are added.
I could be incorrect, but as far as I understand this is done in the CPF, and was done as follows
define_library_set -name TT_LIB -libraries $PATHS_TO_MY_LIBRARIES
set_design $init_top_cell
create_power_nets -nets {VDD_NET VDD_ACC}
create_ground_nets -nets {VSS_NET}
create_power_domain -name {PD_CORE} -default
update_power_domain -name PD_CORE -primary_power_net VDD_NET -primary_ground_net VSS_NET -nmos_bias_net VSS_NET -pmos_bias_net VDD_NET
create_power_domain -name {PD_ACC} -instances $ACC_INST
update_power_domain -name PD_ACC -primary_power_net VDD_ACC -primary_ground_net VSS_NET -nmos_bias_net VSS_NET -pmos_bias_net VDD_ACC
create_nominal_condition -name TT -voltage 0.80
update_nominal_condition -name TT -library_set "TT_LIB"
create_power_mode -name PM_0P80 -domain_condition {PD_CORE@TT PD_ACC@TT} -default
<creating global conditions>
end_design
In cc_opt_mode, I have specified the cells to be used for -cts_inverter_cells, -cts_buffer_cells, and -cts_clock_gating_cells.
The command  `get_ccopt_property buffer_cells -power_domain PD_ACC` returns the list of buffers as expected.
After running
create_ccopt_clock_tree_spec
ccopt_design -outDir RPT/innovus -prefix cts
I do `selectInstByCellName *CKBUF*, and see how buffers have been placed in all areas but the PD_ACC area - which is a bit concerning.
During `optDesign -postCTS -hold -outDir RPT/innovus -prefix -postcts_hold` i get the following
**WARN: (IMPCCOPT-1182): The clock_gating_cells property has no usable full-cycle clock gates for power domain PD_ACC.
For power domain PD_ACC:
For power domain PC_CORE:
Buffers: {<list of buffers>}
Inverters: {<list of inverters>}
Clock gates: {<list of clock gates>}
I assume that I am missing something crucial? I would very much be interested in finding out why the tool believes that the list of buffers, inverters and clock gates, are empty for PD_ACC, as shown in the log above.
Any help in the right direction would be appreciated!
Thank you in advance
INNOVUS 21.11
  • Krippkrupp
    Krippkrupp over 3 years ago +2
    Found the issue. The problem was that I had flattened my design
  • Krippkrupp
    Krippkrupp over 3 years ago in reply to predalco +1
    The issue was that I used setDesignMode -addPhysicalCell flat Either removing it, or changing it to the following setDesignMode -addPhysicalCell hier Solved the issue for me. I found two pages…
  • Krippkrupp
    • Vote Up +2 Vote Down
  • predalco
    predalco over 3 years ago in reply to Krippkrupp
    [deleted]
  • Krippkrupp
    Solved the issue for me. I found two pages on the support page that pushed me in the right direction, but I don't have access to the links anymore.
