  3. Synthesizing Specific Gates in Cadence Genus
  • Subscribers 95
  • Views 7398
SR202412023415
SR202412023415 over 1 year ago
Hello Cadence Community,
I'm working on a flattened netlist in Cadence Genus for a design and would like to apply targeted synthesis optimizations to a specific list of gates (e.g., g1234, g5678) while keeping the rest of the design unchanged. Is it possible to synthesize or optimize only these gates, and if so, how can I achieve this?
My current synthesis script uses commands like syn_generic, syn_map, and syn_opt, but these seem to reprocess the entire design, which I want to avoid. I'm using the NangateOpenCellLibrary_slow_ccs.lib library and have a list of gate names. Ideally, I'd like to apply optimizations such as using different cell types or adjusting attributes only for these gates.
Any guidance on commands (e.g., set_attr, incremental synthesis) or script modifications would be greatly appreciated. Thank you!
Best regards
  • Frontend designer rr
    Frontend designer rr over 1 year ago +1
    # Mark all cells dont_touch set_dont_touch [get_cells *] # Clear dont_touch on target gates only foreach gate {g1234 g5678} { set_dont_touch -clear [get_cells $gate] } # Optionally set mapping constraints…
  • SR202412023415
    SR202412023415 over 1 year ago in reply to Frontend designer rr +1
    Thanks for your reply. I faced couple of questions. First, the "-clear" was not a valid option for me an I needed to use the following command, and I wanted to ensure it's still correct: # set_dont_touch…
    # Optionally set mapping constraints on those gates
    set_map_cell -inst g1234 new_cell_type1
    set_map_cell -inst g5678 new_cell_type2
    # Run incremental optimization (only for gates without dont_touch)
    syn_opt -incremental
    syn_map -incremental
    # Optionally run further incremental steps
    syn_check
    You can try above steps
  • SR202412023415
    # set_dont_touch -help
    set_dont_touch [get_cells {g372734 g372735 g372736 g372737}] false
    Also, set_map_cell was not a valid command for me and I needed to comment it out.
    Additionally, "
    syn_map" does not have -incremental option for me.
    After doing all these steps, when I checked the synthesized design, I realized that the re-synthesized netlist did not change at all.
    I would appreciate your help in advance.
