  2. Functional Verification
  3. Directed vs Random Testing
  • Replies 7
  • Subscribers 70
  • Views 17954
FormerMember
FormerMember over 18 years ago
Hi
I am writing a paper looking at "myths" in functional verification. By "myth" I mean the types of things which people take as accepted truth even though there may not be much evidence to back them up. So, is the death of directed testing one such myth?
My opinion is:
- random has replaced directed as the preferred test methodology at block level (and if you want a directed test you do that via your random test bench)
- but at chip level there is still a lot of directed mainly for many reasons - the main ones being more legacy of test benches at chip level and legacy of thought (i.e. we must see the chip do this before we ship), you want to see specific integration scenarios (although random + coverage could do that too), and because you are often doing HW + SW coverification where directed is more usual
I'm looking for an active discussion plus references to good articles or papers on this topic please
Mike Bartley
  • Giles
    Giles over 18 years ago
    Hi Mike,
    It's great to see people thinking about this stuff.
    I agree with your observations, particularly that directed testing is still dominant at system level, but that in theory random + coverage could replace this. I think that not only could it be a replacement but we could see many of the module level benefits which we have seen repeated in system level verification. A particular benefit might be that coverage is inherently more immune to design changes than a directed test, and so more stable verification reuse from previous evolutions of a system might be achievable.
    So the interesting question is why is it not being widely applied? As you suggest software is probably key. Large parts of the system level functionality are implemented in software so a hardware biased view is no longer sufficient.
    The application of Coverage Driven techniques to embedded software/firmware is an area in which I have be working in now for quite some time and as you know the Incisive Software Extensions (ISX) goes a long way to bridging the hardware bias in advanced verification, bringing embedded software firmly under the CDV umbrella.
    I think that there are potentially other problems in bringing CDV to system level, performance too is key. We need to be sure that CDV does not hamper performance improvements made through abstraction and acceleration. This can be achieved through careful, rather than wholesale, reuse, encompassed in a well worked out system level verification methodology.
    Thanks again for raising this topic.
    Giles Hall
  • stelix
    stelix over 18 years ago
     Mike,
     Great topic. Here are a couple of comments:
     1) Has random replaced directed?
    "All test-cases are born equal, as long as they find bugs" :-)
    Finding bugs is decoupled from the way test-cases are born. The problem with directed testing is that it forces the verifier into a cause-and-effect type of thinking. In other words, the problem is not as much that the user provides inadequate stimulus to the design; it is rather that they are looking for only certain types of errors per test-case.
    So I think it is a relative myth that random "is better" than directed. What really makes the difference is taking the time to write independent monitors, checkers and coverage collectors to be able to detect bugs and extract useful metrics. Once this milestone is reached, randomization can improve productivity but also burn a lot of simulation time.
    2) Chip level vs. block level
    When it comes to chip-level functionality, you offer 3 reasons why directed test is preferred:
        a) Legacy environments and thought
        b) Specific integration scenarios
        c) HW/SW co-verification
     These are all very true. I would also add:
        d) Organizational issues: Folks doing chip-level verification are usually different from the folks doing block-level verification. A lot of times they are software engineers or the bring-up team. They are used to their own tools and methodologies.
        e) "Bang for the buck": A GPU validation team will want to run the complete OpenGL or DirectX compliance suite before signing-off. Do they need more random testing on top? Maybe. Unless a chip-level coverage database has been implemented we simply don't know! So it is important to first invest in chip-level coverage metrics. In many cases, existing directed environments may be "good enough" if we can measure their impact.
       e) Scope: Block-level verification is almost entirely about functionality.Chip level verification can include other components like, say, performance. Performance metrics may be very well defined as stimuli (e.g. specINT performance).
    I am more inclined to adopt constrained-random as a "top-off" type of technique for chip-level verification. However, both random and directed approaches can benefit from expanded use of coverage metrics and associated planning.
    Cheers,
    -Stelix.
  • jasona
    jasona over 18 years ago
    Hi Mike,
    I wrote a blog post that is related to the questions you are asking.
    As Giles mentioned ISX is bringing additional automation, control, randomization, and coverage as a way to improve traditional directed tests. Take a look, feedback is always welcome.
    Jason
  • ThinkVer
    ThinkVer over 18 years ago
    Here's something I wrote on the subject a while ago... :-)
    http://www.thinkverification.com/?p=6
    Yaron
  • adua
    adua over 18 years ago
    Hi Mike,
    Interesting topic. I agree with your thought that random & contraint random is an advanced & better way to do verification closure specially with metric driven verification based on coverage, but directed is not dead.
    However, I would like to add another aspect here. Verification is mostly done with both random and directed, and what is more common depends on the 'stage' of verification i.e. how stable is your DUV is expected to be. Typically verification is mostly started with directed testing (specific basic flow is working like device boot or reaching the initialization stage). So all the basic functions are verified using manual directed testing. Then in the middle stage of verification, it is mostly random testing where you use generate random or interesting scenarios using constraint randomization. Finally in the end the users again do directed testing to test 'corner case' situations that are specific to the device.
    Overall, I would roughly put directed-random-directed as the order of sequence of predominate way of verification.
    -Amit.
  • FormerMember
    thanks Yaron
  • ThinkVer
    ThinkVer over 17 years ago
    My pleasure. The correct link is actually this:
    http://thinkverification.com/index.php/verification-methodology/49-to-randomize-or-not-to-randomize.html
