  2. Functional Verification
  3. Conversion of an Integer port in VHDL to equivalent in ...
  • Subscribers 67
  • Views 17811
Conversion of an Integer port in VHDL to equivalent in Verilog
Sarvesh
Sarvesh over 17 years ago
I am using NC-VHDL and trying to port map a verilog file in the VHDL enviroment. I am not able to convert an integer port which is present in the original file. Is there any workaround for this in Verilog ? I have tried using [15:0] array also a [31:0] array but there is a compilation error as NCVHDL says it cannot find any equivalent matching datatype. Please help.
  • Mickey
    Mickey over 17 years ago
     Hi Sarvesh,
    Just to be clear, you have a verilog module with an integer port and you are instantiating that verilog module in vhdl.  If that's the case, take a look at the example below and let me know if that helps.
    verilog
    module using_integer_port (clk, in1, out1);
    input clk;
    input  in1;
    output out1;
    wire [31:0] in1;
    integer out1;
    always @(posedge clk)
      out1 = in1;
    endmodule
    vhdl
    library ieee;
    use ieee.std_logic_1164.all;
    entity test is
    end test;
    architecture vhdl of test is
    component using_integer_port
           port (clk: in std_logic;
                 in1: in std_logic_vector;
                  out1: out std_logic_vector);
    end component;
    signal clk: std_logic := '0';
    signal d: std_logic_vector (31 downto 0);
    signal q: std_logic_vector (31 downto 0);
    begin
        clk <= not clk after 20 ns;
        process begin
            wait for 3 ns;
                 d <= X"01000111";
            wait for 5 ns;
                 d <= X"11000111";
            wait for 13 ns;
                 d <= X"00011001";
        end process;
        inst:using_integer_port port map (clk, d, q);
    end vhdl;
    Hope that helps.
    Best regards,
    Mickey
  • cubicle82
    cubicle82 over 17 years ago
    input clk;
    input  in1;
    output out1;
    wire [31:0] in1;
    integer out1;
      out1 = in1; // coding style-error, flipflop should be '<='
    endmodule
    As written, your Verilog-module has single bit-wide ports. I don't think Verilog-2001 allows module-ports to be specified as type integer.  (Parameters, function-args, and task-args can be formally specified integer.)
    My VHDL is a bit rusty, but I'm guessing it's shorthand for a 32-bit signed integer?  If that's the case, you could try something like this:
    `define fake_integer signed [31:0]
    module v2001_using_integer_port (
      input wire clk,
      input wire `fake_integer in1,
      output reg `fake_integer out1
      out1 <= in1;
    endmodule
