  2. Functional Verification
  3. Layout Instance Names on VNL Netlists?
  • Subscribers 67
  • Views 14952
moss
moss over 17 years ago
  I've been trying to understand what is documented on layout's VNL netlist. It seems that the system has assigned names for the pins on the layout. Is there a way to determine the link between the names in VNL netlist and layout view?
   For example, my capacitor(pcell) in the layout  has "I0" as it's name on the layout (shown on the "Edit Instance Properties" box). However,assura refers to  "avD2187_2 " instead of "I0" in both VNL netlist and LVS debugger. With that, I have no choice but to open up the debugger and highlight all the instances in the debugger in order to determine which instance on my layout has LVS mismatches instead of reading the output alone.
   I would be grateful if someone can provide some leads into this issue.
  • tpylant
    tpylant over 17 years ago
    You might want to post this on the Custom IC forum since they deal with the Virtuoso netlisters more over there.
    Tim
