  2. Functional Verification
  3. Verilog Name Collisions - irun v8.1
  • Subscribers 67
  • Views 2164
Dave123
Dave123 over 17 years ago
I am trying to simulate a chip that consists of several DSP blocks with irun v8.1. The DSP blocks are written in a high level tool which then generates a verilog model for each block. Unfortunately, common names are used in DSP blocks for modules which are not functionally equivalent. As a result, the chip cannot be simulated properly at the top level. The simulator applies the last module compiled to each DSP block.
 Is there an easy way around this short of renaming all the sub-modules in the DSP block?
  • tpylant
    tpylant over 17 years ago
    You can accomplish this but you'll have to use the three step method of ncvlog, ncelab, ncsim. What you'll want to do is compile each DSP block (and associated files) into its own library. You can do that by having a separate directory for each DSP and then create a hdl.var and cds.lib file like this:
    hdl.var
    define LIB_MAP (       \
      ./one   => oneLib,   \
      ./two   => twoLib,   \
      ./three => threeLib, \
      +       => workLib   \
    cds.lib
    define oneLib work/oneLib
    define twoLib work/twoLib
    define threeLib work/threeLib
    define workLib work/workLib
    This is just one idea. You can get some more ideas in the NC-Verilog Simulator documentation under the chapter explaining the elaborator.
    Tim
  • StephenH
    StephenH over 17 years ago
     I haven't had time to try it for a Verilog design, but the irun option "-makelib" might work for this scenario. Simply use -makelib and -endlib to delimit the range of files that go into each DSP library, something like this:
    irun -makelib dsp1 rtl/dsp1/*.v -endlib -makelib dsp2 rtl/dsp2/*.v -endlib
