  2. Functional Verification
  3. Doe's this 'dist' constraint is legal?
  • Subscribers 67
  • Views 1644
Main
Main over 17 years ago
 I tried to use the following constraint (dist) which I'm not sure is syntatically legal.
Anyway, the NC simulator compiled it without warnings but it didn't work as expected in simulation:
cmd_kind dist { {CFG_WR, PGM_WORD, PGM_PAGE, READ_PAGE, READ_WORD} := 10, SW_RESET := 1};
In simulation I got only SW_RESET cmd kind.
The alternative is to explictly define weight for each item of the {} group which is really not comfortable.
Does anyone know if by SV LRM this should have worked?
  • StephenH
    StephenH over 17 years ago
    I think you wanted to use square brackets instead of curly ones, around the range:
    cmd_kind dist { [CFG_WR, PGM_WORD, PGM_PAGE, READ_PAGE, READ_WORD] := 10, SW_RESET := 1};
    And I'm assuming you had this inside a constraint block or "randomize() with" construct...
  • Main
    Hey StephenH, Are sure the syntax you suggested is legal? I tried that already before and the Compiler was expecting ':' meaning [a:b] and not a list.
  • StephenH
    Yes, sorry, I misread your original question.
    The LRM doesn't showany examples of what you're trying to do. The ranges are always contiguous, as in:
    x dist { [100:102] := 1, 200 := 2, 300 := 5}
    Also, the formal syntax suggests that the range must be in the form [a:b] and not a list of non-consecutive numbers, so I guess what you wanted to do is not legal according to the LRM.
