  2. Functional Verification
  3. reversed part select index expression ordering
  • Subscribers 67
  • Views 26324
linseed
linseed over 17 years ago
I use NCverilog to do the simulation. and got erros in ncelab.log as follow:
ncelab: *E RNGDIR (../simprims/X_ARAMB36_INTERNAL.v 2182 | 23) reversed part select index expression ordering [4.2.1 [ IEEE]]
 doa_ltmp[7:0] = mem[addra_tmp[14:4]] [7:0];
Is there something wrong in the ARMB36 model or in my simulation tool,   can anybody help me? !!!
Thanks!
  • Mickey
    Mickey over 17 years ago
     perhaps the nchelp output for the error your seeing may help:
      unix>  nchelp ncelab RNGDIR
    nchelp: 08.20-s008: (c) Copyright 1995-2009 Cadence Design Systems, Inc.
    ncelab/RNGDIR =
    The two expressions that make up a part-select are in the wrong
    order with respect to the declaration of the object being
    selected. Please check that the declaration and select
    expressions in the part-select conform. This error also occurs
    if one of the expressions has an unknown value.
    Hope that helps.
    Mickey
  • Shalom B
    Shalom B over 17 years ago
    Apparently, addra_tmp is declared from low to high, whereas you have written a part-select of [14:4], from high to low.
    Shalom
