  2. Functional Verification
  3. SystemVerilog queue of classes
  • Subscribers 67
  • Views 25074
flanter
flanter over 17 years ago
Hi all,
I try using a queue of classes but there seems to be a problem when trying to read an item from the queue. I always receives only the last item pushed into the queue... I built the following test case:
code starts here:
module tst_case_queue_of_class ();
class cls_tmp;
    byte tmp1;
    byte tmp2;
endclass
cls_tmp cls_q[$];
cls_tmp in_item = new();
cls_tmp out_item= new();
initial
begin
    #10;
    in_item.tmp1 = 8'h00;
    in_item.tmp2 = 8'h01;
    cls_q.push_back(in_item);
    #10;
    in_item.tmp1 = 8'h01;
    in_item.tmp2 = 8'h02;
    #10;
    in_item.tmp1 = 8'h03;
    in_item.tmp2 = 8'h04;
    #10;
    in_item.tmp1 = 8'h05;
    in_item.tmp2 = 8'h06;
    for (int i = 0; i < cls_q.size(); i++)
    begin
        $display("index= %1d: tmp1=0x%2h, tmp2=0x%2h",i ,cls_q[i].tmp1 ,cls_q[i].tmp2);
    end // for (int i = 0; i < cls_q.size(); i++)
    repeat(4)
    begin
        out_item = cls_q.pop_front();
        $display("q_size= %1d: tmp1=0x%2h, tmp2=0x%2h",cls_q.size() ,out_item.tmp1 ,out_item.tmp2);
    end // repeat(4)
end // initial
endmodule
Results of the simulation:
index= 0: tmp1=0x05, tmp2=0x06
index= 1: tmp1=0x05, tmp2=0x06
index= 2: tmp1=0x05, tmp2=0x06
index= 3: tmp1=0x05, tmp2=0x06
q_size= 3: tmp1=0x05, tmp2=0x06
q_size= 2: tmp1=0x05, tmp2=0x06
q_size= 1: tmp1=0x05, tmp2=0x06
q_size= 0: tmp1=0x05, tmp2=0x06
code and simulation results stop here
What is the problem with queue of classes? By the way, when trying to use a queue of structs I receive a compilation error...
Flanter
  • tpylant
    tpylant over 17 years ago
    The problem is that you're storing the class handle in the queue. Each time you put data into the class object, it is putting it into the same class object.
    What you need to do is create a new class object for each of the data sets:
    initial begin
        in_item = new();
        #10;
        in_item = new();
    #10;
    end
    Tim
  • flanter
    Thanks Tim!
    You are right. It solved the problem.
