  2. Functional Verification
  3. PSL equivalent for SVA action block
  • Subscribers 67
  • Views 15296
Arturi
Arturi over 17 years ago
Hello all,
my verilog testbench has a global variable that counts the number of errors during a simulation. Every time an error is detected during the simulation the global variable gets incremented. At the end of the simulation, the testbench checks this variable to decide if the simulation is a PASS or a FAIL.
This works fine for HDL checkers but not for PSL assertions.
How can I increment this global variable when a PSL assertion fires?
SVA supports this with action blocks. Does PSL have something equivalent? I read something about a ended() construct but still not sure how to use it.
Any feedback is welcome.
cheers
  • JoergM
    JoergM over 17 years ago
    Hi Arturi,
    there is no equivalent in PSL to a SVA action block. Actually there is no feedback from PSL to HDL at all, I believe this was done for a simple reason to keep verification and design separate and not allow loops.
    The only way to determine and count or report the failures in on tool level. In ncsim there is a "assert -sum" comand for example. In addition you can place breakpoints on assertions. Especially with breakpoint there is possible backdoor access to achive what you want: Set a breakpoint on every failing assertion, that deposits a value on a particular signal in the testbench and then continues. You can imagine how to use  this signal to increment the failure counter throughout the simulation.
    stop -assert test -depth all -continue -exec {deposit test.error_flag 1}
    Joerg.
  • Arturi
     That's helpful! Thank you!!!
    Schoene Gruesse nach Feldkirchen :)
