  2. Functional Verification
  3. Unresolved adapter error: ERR_DID_NOT_FIND_ADAPTER
  • Subscribers 67
  • Views 15283
random
random over 17 years ago
Hi all
I have a mixed environment with a vhdl testbench and i am trying to access an internal signal which is verilog. I had a working environment when i used older version of specman 5.xx a couple of years ago. When i try the same with the new version of specman 8.1x, I get the following error.
I constrained the agent() of the unit instance to verilog.
keep soft abc.._u.agent() == "verilog";
    Opening file for message: abc_testbench.elog
   *** Error: ERR_DID_NOT_FIND_ADAPTER: Unresolved adapter identification name 'Verilog'.
When you set this condition to a severity of WARNING or IGNORE, then
the NULL_SIM adapter is used instead.
Any help in resolving this is greatly appreciated.
  • random
     I figured the problem is because i did not recreate the stubs file. It will take a while before i can create a stubs file for the entire project as i have to wait for others to clean up their code.. but hopefully it will work.. if not, i will repost the query.
    kk
