  2. Functional Verification
  3. IUS82s012: is this legal "for ( genvar g = 0; g < 4; ++g...
  • Subscribers 66
  • Views 2650
IUS82s012: is this legal "for ( genvar g = 0; g < 4; ++g ) ..."?
cubicle82
cubicle82 over 17 years ago
I tried auto-declaring a generate-var inside a generate-block:
module a;
wire [3:0] x;
generate
for ( genvar g = 0; g < 4; ++g ) begin :gen_g
    assign x[g] = 1'b0;
end : gen_g
endgenerate
endmodule : a
irun-8.2s012 gives me this error-message:
ncvlog: *E,FNDKWD (a.sv,6|11): A Verilog keyword was found where an identifier was expected.
Naturally, I can just move the 'genvar g'  oustide of the for() block.  But it would be nice to be able to use inline-style of loop-var declaration with genvars.
  • StephenH
    StephenH over 17 years ago
    Hi Cubicle82.
    I glanced at the LRM, and the use of inline genvar only appears to be legal in 1800-2005, not in the older 1364-2001 standard.
    Since the work-around is so simple, I'm guessing R&D hadn't prioritised it yet.
    BTW, in your example, did you realy mean to pre-increment the genvar (++g) instead of the more usual post-increment (g++)?
    It just looked a bit odd... :-)
    Steve.
  • cubicle82
    RE: ++g vs g++
    Oh, it's an old habit! In C/C++ code, I very rarely embed a dec/inc index-operation with data-manipulation.  I.e.:
      str[ i++ ] = 0;
      or my least favorite: *optr++ = *iptr++;
    Instead, I tend to separate it into multiple statements, simply because I find it easier to read.  Other programmers will use both forms, depending on the loop-situation.  Although the code is more compact, I (personally) find it harder to read, especially late at night after staring at the monitor for 5 hours :)
