  2. Functional Verification
  3. New to SV: Disabling of assertions from a task?
  • Subscribers 67
  • Views 19840
rossbthompson
rossbthompson over 16 years ago
I am in the process of creating SV checkers for an existing environment. I am trying to find a way to disable all assertions for a given test. The test in question is a force/check style which throws off all of the assertions. I have seen a method of doing this from TCL, but would like to do it from a task (current test method).
 Any recomendations appreciated
Ross
  • TAM1
    TAM1 over 16 years ago
    You can use the SystemVerilog $asserton, $assertoff and $assertkill system tasks to control assertion operation.
  • rossbthompson
     Thank you, That is exactly what I needed. I was lost in my 7 open pdf files and missed that.
  • StephenH
    StephenH over 16 years ago
    Hmm... is that a subtle dig?
    Have you tried using the doc browser "cdnshelp" instead of the PDFs? The searching should generally be a lot better, and you can search across all / some of the manuals / products rather than one-at-a-time.
  • rossbthompson
     No dig intended. Just a statement of my experience level in SV. I wasnt sure what I was looking for.
    I tend to use my pc for my document reading. For Specman, I used to copy over the whole html tree and could use the search through the main web page. Is there a similar option for the other Cadence products?
    current open pdf's:
    ncvlog.pdf
    sv_lrm.pdf
    vmm_sv.pdf
    iccug.pdf
    sysverilog.pdf
    abvwrite.pdf
    abvguide.pdf
