  2. Functional Verification
  3. CPU & Memory Usage details in ncverilog log file.
  • Subscribers 67
  • Views 2790
Rdbabu
Rdbabu over 16 years ago
I'm trying to do profiling on specman e code using nc-verilog simulatior 8.2 and IUS specman 8.2.
The specman profiling is done for a small block and to a core block.The goal  is also  to know the details of CPU and Memory Usage which is seen at the end of the log file.
For block I could see this information as shown below
<<< End of Test >>>
nc_specman is doing end-of-test operations Checking the test ...
Checking is complete - 0 DUT errors, 0 DUT warnings.
Post-processing profiling data ...
..samples_counter 1927
Creating the report ...
Done.  Report saved in sn_prof.16244/report_mem.html End-of-test operations are completed
Memory Usage - 16.5M program + 245.7M data = 262.2M total
CPU Usage - 4.0s system + 362.2s user = 366.2s total (95.5% cpu)
Simulation complete via $finish(2) at time 58837852 PS + 0
( This was not run with Intelligen )
When I tried the same for core block, I couldn't see the details of the CPU and Memory Usage but the profiler report is generated as shown below
<<< End of Test >>>
...samples_counter 2529
Done.  Report saved in sn_prof.29016/report_mem.html End-of-test operations are completed Simulation complete via $finish(1) at time 45770913568 FS + 0
(This was run with Intelligen )
What could be reason for those Usage details not being printed in the second log file?
What factors determines to display the Usage details in the log file?
-DB
  • Hilmar
    Hilmar over 16 years ago
     Could you post the command scripts you use for both to compare?
    Thanks!
    Hilmar
  • Rdbabu
      For comparing the profier report we can use sn_profile.sh -diff report1 and report2. At present no script is developed. The query here when and all the log file doesn't show those usage details.
    regards
    DB
