  2. Functional Verification
  3. System Verilog with Spice *F,INTERR - cu_check_port_var...
  • Subscribers 67
  • Views 1629
System Verilog with Spice *F,INTERR - cu_check_port_var_aca
GraemeNunn
GraemeNunn over 16 years ago
I am trying to use a system verilog testbench to verify a spice block. The aim is to have system verilog stimulus and monitoring using real values.I have example with the stimulus side working but not the monitoring.
When I run my simple example I receive the following error during elaboration. What am I missing from the configuration to get this working?
(This testcase started off as the spice_in_middle example from the AMSD workshop)
Graeme Nunn
 ncelab: *F,INTERR: INTERNAL ERROR
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL: ncelab  08.20-s009
  HOSTNAME:
  OPERATING SYSTEM: Linux 2.6.9-89.0.20.ELsmp #1 SMP Mon Jan 18 12:19:33 EST 2010 x86_64
  MESSAGE: cu_check_port_var_aca - not net, class 520, file: top.sv, line:6
 Input Files:
Run
#! /bin/csh -f
irun    *.sv \
        *.vams \
        amscf.scs \
        -timescale 1ns/100ps \
        -mess
pot.sp
.subckt pot rtop rmid
r1 rtop rmid 10k
r2 rmid 0 10k
.ends
top.sv
module top ;
  timeunit      1ns ;
  timeprecision 1ns ;
  harness h1 (.resp(out),.sig(sig));
  pot p1 (.rtop(sig),.rmid(out));
endmodule : top
harness.sv
module harness (resp,sig);
        output real  sig ;
        input var real resp ;
        var real sig_r;
        assign sig=sig_r;
        initial begin
                sig_r=0.0;
                #10 sig_r=1.0;
                #10 sig_r=2.0;
                #10 sig_r=3.0;
                #10 sig_r=2.0;
                #10 sig_r=1.0;
                $finish;
        end
        always @(resp) $display("Resp has changed to %0f",resp);
endmodule
amscf.scs
include "./pot.sp"
* AMS Control file
include "top.scs"
amsd {
        portmap subckt=pot file="pot.pb"
        config cell=pot use=spice
        ie vsup=1.8
top.scs
simulator lang=spectre
rawFmtOpt options rawfmt=sst2fbin   maxwarnstologfile=1000 maxnotestologfile=1000
saveNodes options save=all
timeDom tran stop= 30us
pot.pb
 //*** pot.pb ***
//* Portbind file for:
//* SPICE subckt pot : HDL module pot
//* SPICE port  :       HDL port        :       HDL Parameters
rtop    :       rtop    :       dir=inout
rmid    :       rmid    :       dir=inout
  • StephenH
    StephenH over 16 years ago
    Hi Graeme.
    I tried to reproduce this from the files that you pasted into your post, but either you missed some *.vams files, or the irun command is wrong.
    Since the error message is an internal error (*F,INTERR) in ncelab, it would be helpful if you could open a service request at http://support.cadence.com/ so that the support team can look into this in more detail.
    Cheers.
    Steve
