  2. Functional Verification
  3. mixed language simulation
  • Subscribers 66
  • Views 15433
josephbell
josephbell over 15 years ago
Hello all
 i am doing verification of a blocks that has vhdl modules instantiated in the verilog top module. the vhdl modules are using the xilinx libraries like unisims / corelib. i have compiled the libraries and vhdl modules are picking up those libraries. i am having problem while elaborating the design. i am using following commands for simulating the design: ncvhdl -v93 -f filelist_vhdl
ncvlog -f filelist_ver
ncelab -access +rw +mixedlang tb_module -v93
while elaborating i am getting following error:  ncelab: *E,CFIGTC saying the VHDL generic bit_vector type is not compatible with verilog. and the bit_vector is declared in the xilinx library primitives.
i cannot change the type bit_vector to std_logic_vector  as these are standard libraries and ihave no permission to modify them.
can anybody help me out.
thanks
vishal
  • StephenH
    StephenH over 15 years ago
    Hi Vishal.
    I believe that Xilinx supply both VHDL and Verilog versions of their unisim libraries. I worked with someone else this week who saw the same issue as you. In the end it turned out to be that he was using a Verilog design, with the VHDL unisim library.Afterhe switched his cds.lib to point to unisim_ver instead of unisim, it worked OK.
    Since you say your design is VHDL, perhaps you could check your cds.lib to see if you have unisim_ver in there already; if so, swap it to unisim.
    Regards.
    Steve.
  • josephbell
    Thanks Steve. i have already done this, instead of using VHDL unisims i changed the cds.lib to pick up the Verilog unisims. this has worked for me. Thanks for the information.
    Vishal
  • larryp7639
    larryp7639 over 15 years ago
    StephenH said:
    Hi Vishal.
    Regards.
    Steve.
    me too :D
    __________________
    Watch The Sorcerer’s Apprentice Online Free
  • jenkinrob
    jenkinrob over 15 years ago
    We worked with somebody else now who noticed the exact same issue while you. Within the end it turned out to be he had been utilizing a Verilog style, using the VHDL unisim library.Afterhe changed his cds.lib in order to indicate unisim_ver rather than unisim, it proved helpful Ok.
    Because you state your style is VHDL, possibly you could check your compact disks.lib to determine for those who have unisim_ver within currently; if so, swap it to unisim.
