  2. Functional Verification
  3. What is the correct syntax for forcing signal in a Verilog...
  • Subscribers 68
  • Views 41260
What is the correct syntax for forcing signal in a Verilog testbench
Blaise70
Blaise70 over 15 years ago
Hi All,
I have a Verilog testbench where I would like to force some signals.
I'm using the following code in my Verilog file:
$nc_force("/full_path/sugnal_name","'b1");
Compilation seems to be OK, but during run-time I get the following error message:
ncsim: *E,SETNEL: Poorly formed string/enumeration literal: 'b1.
Can someone give me the correct syntax for the value to be forced? I have already tryed a lot of different strings, but none of them works.
Thanks in advance.
Best regards,
Blaise70
  • StephenH
    StephenH over 15 years ago
    Did you try without the 'b part?
    In case you're not aware, the 6 letter error code can be used to display additional information:
    % nchelp ncsim SETNEL
    nchelp: 09.20-s031: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
    ncsim/SETNEL =
            An attempt was made to force/nc_mirror a VHDL object using an invalid
            string or enumeration literal.
            Examples:
                    {"0001"}        -- legal
                    {"howdy"}       -- legal for a string type VHDL object
                    X"DF"           -- legal, format specifier can be used
                    {X"DF"}         -- legal, format specifier can be used
                    'a'             -- legal
                    {"0XXX_1111"}   -- underscores are legal
                    "0001"          -- invalid, '"' need to be escaped
                    {"FALSE, FALSE, TRUE"}    -- invalid for a boolean type
                    '_'                       -- invalid
                    '0',                      -- comma after the literal is invalid
    Notice how none of the examples use 'b.
  • Blaise70
    Hi Stephen,
    Thank you very much for your kind help.
    Yes, I have tried it without 'b.
    I have used the followings:
    $nc_force("full_path/signal_name","1");
    $nc_force("full_path/signal_name","'1'");
    None of the aboves works for me.
    However the below one for multiple bits wide signal seems to be fine.
    $nc_force("full_path/signal_name","1001");
    Thanksfor your help again.
    Best regards,
    Blaise70
  • StephenH
    Hi Blaise70.
    I made a little trial and it works for me:
    module dut;
    wire abc;
    endmodule
    module tb;
    initial $nc_force("dut_i.abc","1");
    dut dut_i();
    endmodule
    It also works when I make the target wire into a VHDL signal.
    What's different about your design?
  • Blaise70
    Hi Stephen,
    For me it seems that there is no difference except that my forces are placed into a separate module and into a separate verilog file.
    An instance of this module is implemented in my test bench.
    Anyway I will also make a try with a simpler dummy project and see what happens.
    Thanks and regards,
    Laszlo
  • Ravisinha
    Ravisinha over 15 years ago
    $nc_force("/full_path/sugnal_name"," '1' "); Basically between double quotes we have to use single quote.
  • Blaise70
    Yes, thats correct, but it is a mixed language design, Verilog/VHDL/Verilog and thats causes NCSIM to complain on several things.
    Finally we have found a SW work around so these forces are not required on gate level. I think it is much safer approach.
     Thanks for your help.
    Best regards,
    Laszo
