  2. Functional Verification
  3. mvl value duing @sim
  • Subscribers 67
  • Views 14915
arjuny
arjuny over 15 years ago
Hi, what should be the output of the following code? sig_a is bind to wire "a" in verilog top file which has transitions "X -> Z -> 0 -> 1 -> Z -> 1". event a_c_e is change(smp.sig_a$)@sim; on a_c_e { print smp.sig_a.get_mvl(); }; The log file is showing "mvl_z" when the transition happens from "x" to "z". I am assuming that the specman should print "MVL_X" as the specman samples the previous value at change of signal not the updated value. Please correct me if i am wrong. Thanks
  • Ravisinha
    Ravisinha over 15 years ago
    Hi Arjun, Are you sure that your event "a_c_e" is occurring while the signal is changing from X to Z... because what i am thinking that it may be that your event is occurring when it is changing to 0 and thats why you are getting the get_mvl() value as "Z".. which is the previous value.
  • arjuny
    Hi Ravi,
       I am sure because i have used "print sys.time" at every  transition.
       The trnasition from x->z happening at time "0" and the value it is printing is "MVL_Z" at that time.
    Thanks.
