  2. Functional Verification
  3. vplan in xls format
  • Subscribers 68
  • Views 19925
vplan in xls format
nirmit shah
nirmit shah over 15 years ago
I want to use vmanager tool for functional verification. For this I have to create a vplan.
Can anyone have a idea that vplan only supports document format (like a word doc) or we can use xls format for vplan and then change it to xml for vmanager tool ?
Nirmit
  • nishvlsi2011
    nishvlsi2011 over 15 years ago
    Hi Nirmit, You can use enterprise planner to create a vplan. I don't think xls format is supported by vmanager. vmanager will support .xml or .sxw (openoffice) or .vplan (from eplanner) files. Converting a xls to xml and then using it in vmanager tool, I am not sure about that. Regards, Manish
  • StephenH
    StephenH over 15 years ago
    Hi Nirmit.
    As Manish pointed out, Enterprise Planner (Linux command is "eplanner") is the preferred way to capture plans, as the tool offers a lot of automation and cool features that just cannot be supported by Word, XLS etc. For example, eplanner can connect the vPlan entries to your original spec files and your coverage, and audit any changes.
    If you do want to work with XLS, we have ways to handle that. Please contact your local Cadence AE for more info (or ping me your contact details and I'll help put you in contact with your AE).
    Steve.
  • pcarzola
    pcarzola over 15 years ago
    Good answer. Thanks.
    -Paul
