  2. Functional Verification
  3. Failed to find SETUP/HOLD timingcheck
  • Subscribers 67
  • Views 2840
tswong
tswong over 15 years ago
I am performing postlayout simulation for a digital design which adopts TSMC 65nm standard cell library. During SDF back annotation by Verilog-XL 8.2, there are many SDFA errors, "Failed to find SETUP timingcheck" and "Failed to find HOLD timingcheck". But the simulation is still passed. Is it caused by mismatch Verilog model of the standard cells? or by improper EDA tools? Is it important?
Thanks!
  • Mickey
    Mickey over 15 years ago
    The message is indicating that you have HOLD and SETUP timing checks in the sdf file, but there is no SETUP or HOLD timing checks specified in the verilog specify block of the RTL.  Consequently the simulator is not able to annotate those timing checks.  This will not cause the simulator to exit or fail, but it will result in the timing checks in the sdf not being performed.
    By the way, If at all possible I would recommend using ncverilog rather than verilog-xl (VXL).  To do that simply replace the "verilog" on the command line with "ncverilog".  That is more than likely not going to fix the problem, but going forward I would suggest using nc-verilog because it is the simulator that is continually being updated with newer functionality.
    Best regards,
    Mickey
