  2. Functional Verification
  3. ahb evc: Hw can I do a random back to back transfer with...
  • Subscribers 69
  • Views 16316
ahb evc: Hw can I do a random back to back transfer with random address
Anukrishnan
Anukrishnan over 15 years ago
Hi ,
I want to do a random back to back transfers, by constraining the ahb evc in specman.Basically I need the htrans as 2-0-2-2-2-2-0-2-0-2-2-2-2-  etc  with random address .So how can I constrain the ahb-evc  to get a sequence like this? Thanks in advance.
  • Vlad Mocanu
    Vlad Mocanu over 15 years ago
    If I understand well, you are trying to send multiple SINGLE bursts with
    some IDLE states along the way (you have to use multiple bursts, if you
    want to have random addresses - due to the nature of the AHB bursts:
    INCR or WRAP). A direct approach, as I see it would be like this:
    extend vr_ahb_master_seq_kind : [ PATTERN_SEQ ];
    extend PATTERN_SEQ vr_ahb_master_seq {
    	!ahb_burst : SINGLE vr_ahb_master_driven_burst;
    	body()@driver.clock is {
    		//htrans will be 2
    		do ahb_burst;
    		//htrans will be 0, then 2
    		do ahb_burst keeping {
    			it.transmit_delay == 1;
    		//the other remaining bursts with htrans 2
    		for i from 1 to 2 do {
    			do ahb_burst;
    Of course, everything will go as smooth as I said if there is no
    arbitration in the environment (ex: using a single master environment
    with vr_ahb_lite_env). Also the whole sequence may stretch in time, due
    to hresp signal from the slave or other response then OKEY.
    After this in your MAIN vr_ahb_master_seq or in your virtual sequence
    you will repeatedly call the PATTERN_SEQ, defined above.
    Hope this will solve your problem.
  • J1EM1N
    J1EM1N over 10 years ago
    Hi, thanks in advance. I have a similar question.
    I want to send multiple SINGLE bursts with no intervals in between. like 2-2-2-2-2-2-2-2...
    However, when I use the following source code, I got a couple of IDLE cycles like 2-2-0-2-2-2-0-2-0-2..., and I don't understand why. Can you help me?
    (I am using non_blocking_write api instead of do burst, so there will be no 1 cycle loss between bursts.)
    struct ahb_trans{
    trans_type : vr_ahb_burst_kind;
    trans_dir : vr_ahb_direction;
    trans_size : vr_ahb_transfer_size;
    trans_addr : vr_ahb_address;
    trans_data : vr_ahb_data;
    extend vr_ahb_master_seq_kind : [ MY_SEQ ];
    extend MY_SEQ vr_ahb_master_seq {
    !ahb_trans;
    for i from 0 to 10 {
    gen ahb_trans;
    non_blocking_write( ahb_trans.trans_addr,
                                         {ahb_trans.trans_data},
                                          ahb_trans.trans_type,
                                          ahb_trans.trans_size);
