  2. Functional Verification
  3. NC VHDL "simulation error"
  • Subscribers 67
  • Views 1725
kovibb
kovibb over 14 years ago
Hi everybody, I use Design Entry HDL for scheme and layout design a few years. Now i want to upgrade me with VHDL simulation so i try to use NC VHDL simulator for that. I start with basis and don't run a lot of time I hit to first problem. When i set up simulator, generate netlist from schematic and generate testbanch than i try it simulate. Simulator show mi this error message after binding and before compilating design process: img256.imageshack.us/.../diffncvhdl.png Just to be sure, I attach link for project: rapidshare.com/.../dff.zip Schematic contains a one simply D flip-flop device. Code is write in VDHL language. Can you give me please same advices or solutions? Thank all
  • StephenH
    StephenH over 14 years ago
    From your screenshot it looks like you are trying to run ncvhdl under Windows from Allegro 16.0, right? That version isn't supported any more, as it's 5 years old! Cadence doesn't support Windows for the Incisive simulator (which ncvhdl is part of), it's been about 6 years since we dropped support for Windows. If you have access to a Solaris or Linux machine, then you should be able to install Allegro (SPB) on on of these platforms, where we do fully support the logic simulator. The latest SPB version is 16.5 and is available from http://downloads.cadence.com/. Regards, Steve.
  • kovibb
    Thank you for your reply. I haven't hunch that in this can be problem.
