  2. Functional Verification
  3. $nc_mirror issues not seen within this forum
  • Subscribers 67
  • Views 20561
damo1865
damo1865 over 14 years ago
I am using the $nc_mirror system task to mirror a VHDL signal to a system verilog environment. The strange thing is that if i include the "verbose" option then it works fine except that there are lots of messages written to screen.
 If i remove the "verbose" option then i get an ncsim.err exception.
Works: $nc_mirror("destination","source","verbose");
Doesnt work: $nc_mirror("destination","source");
Doesnt work: $nc_mirror("destination","source","");
Is there a string that can replace verbose which will minimize the amount of messages written to screen?
Any help would be greatly appreciated.
  • TAM1
    TAM1 over 14 years ago
    Your second example "$nc_mirror("destination","source");" should work fine. Can you show us the error message? If the simulator is crashing, then you might have to file a bug report. No matter what you pass in, the simulator shouldn't crash.
  • damo1865
    Hi Tam1,
    Thanks for the quick response. I have copied the internal failure below. Im just surprised that there is no keyword which is the opposite of verbose to switch off error messaging.
    Regards,damo1865
    csi-ncsim - CSI: Command line:
    ncsim
    -f /var/vob/timm/module/vob/units/bccu/simulation/damien/INCA_libs/irun.lnx86.10.20.nc/vihlc697_12101/ncsim.args
    -INPUT @source /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/files/tcl/uvm_sim.tcl
    +UVM_VERBOSITY=UVM_LOW
    +define+OP_CHECK_ON
    -sv_lib /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/lib/libuvmpli.so
    -gui
    +UVM_TESTNAME=coarse_rand_te0
    -COVTEST te0r
    -COVOVERWRITE
    -TCL
    -MESSAGES
    -SV_LIB /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/lib/libuvmdpi.so
    +EMGRLOG ./logs/coarse_rnd_0.log
    -XLSTIME 1332423364
    -XLKEEP
    -XLMODE ./INCA_libs/irun.lnx86.10.20.nc
    -RUNMODE
    -CDSLIB ./INCA_libs/irun.lnx86.10.20.nc/cds.lib
    -HDLVAR ./INCA_libs/irun.lnx86.10.20.nc/hdl.var
    -XLNAME irun
    -XLVERSION TOOL: irun 10.20-s100
    -XLNAME ./INCA_libs/irun.lnx86.10.20.nc/vihlc697_12101
    -CHECK_VERSION TOOL: irun 10.20-s100
    -LOG_FD 4
    -LOG_FD_NAME ./logs/coarse_rnd_0.log
    -cmdnopsim
    -runscratch /var/vob/timm/module/vob/units/bccu/simulation/damien/INCA_libs/irun.lnx86.10.20.nc/vihlc697_12101
    csi-ncsim - CSI: *F,INTERR: INTERNAL EXCEPTION
    Observed simulation time : 200008 NS + 1
    The tool has encountered an unexpected condition and must exit.
    Contact Cadence Design Systems customer support about this
    problem and provide enough information to help us reproduce it,
    including the logfile that contains this error message.
    TOOL: ncsim 10.20-s100
    HOSTNAME: vihlc697
    OPERATING SYSTEM: Linux 2.6.18-274.3.1.el5 #1 SMP Fri Aug 26 18:49:02 EDT 2011 x86_64
    MESSAGE: sv_seghandler - trapno -1 addr(0x00000004)
    csi-ncsim - CSI: Cadence Support Investigation, recording details
    Simulator Snap Shot: wma (SSS_WMA) in snapshot worklib.top:sv (SSS)
    Intermediate File: root (IF_ROOT) in snapshot worklib.top:sv (SSS)
    Verilog Syntax Tree: register declaration (VST_D_REG) in verilog_package worklib.bccu_xactor_pkg:sv (VST)
    File: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line 15, position 21
    Scope: bccu_xactor_pkg::bccu_channel
    Decompile: bit rtl_chint
    Source : bit [11:0] rtl_chint;
    Position: ^
    Verilog Syntax Tree: bit type (VST_T_BIT) in verilog_package worklib.bccu_xactor_pkg:sv (VST)
    Decompile: bit
    Simulator Snap Shot: fta (SSS_FTA) in snapshot worklib.top:sv (SSS)
    Verilog Syntax Tree: indexed vector type (VST_T_INDEXED_VEC) in verilog_package worklib.bccu_xactor_pkg:sv (VST)
    Decompile: bit
    Verilog Syntax Tree: overlay table (VST_OVERLAY_TABLE) in verilog_package worklib.uvm_pkg:sv (SIG) <0x0fb43995>
    Decompile: bccu_xactor_pkg::bccu_channel
    Intermediate File: ffstructa (IF_FFSTRUCTA) in snapshot worklib.top:sv (SSS)
    Intermediate File: data block (IF_BLK) in snapshot worklib.top:sv (SSS)
    Simulator Snap Shot: mirrors (SSS_MIRRORS) in snapshot worklib.top:sv (SSS)
    Intermediate File: array of pointers (IF_PTRBLK) in snapshot worklib.top:sv (SSS)
    Verilog Syntax Tree: class declaration (VST_D_CLASS) in verilog_package worklib.bccu_xactor_pkg:sv (VST)
    File: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line 9, position 17
    Source : class bccu_channel extends uvm_subscriber #(bccu_data);
    Position: ^
    Verilog Syntax Tree: task declaration (VST_D_TASK) in verilog_package worklib.bccu_xactor_pkg:sv (VST)
    File: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line 502, position 27
    Scope: bccu_xactor_pkg::bccu_channel::get_chint
    Decompile: get_chint
    Source : task bccu_channel::get_chint();
    Position: ^
    Native Code Stream (t=200008000000): Task get_chint (file: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line: 502 in worklib.bccu_xactor_pkg [package])
    Verilog Syntax Tree: task declaration (VST_D_TASK) in snapshot worklib.top:sv (SSS)
    File: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line 518, position 14
    Scope: worklib.bccu_xactor_pkg::bccu_channel@11237_6.get_chint
    Source : 2: $nc_mirror("rtl_chint","top.DUT_wrapper.bccu_i:all_chint[2]");
    Position: ^
    Native Code Stream (t=200008000000): Task linear_walk (file: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line: 227 in worklib.bccu_xactor_pkg [package])
    File: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line 231, position 10
    Scope: worklib.bccu_xactor_pkg::bccu_channel@11237_6.linear_walk
    Source : get_chint();
    Position: ^
    Native Code Stream (t=200008000000): Task run (file: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line: 169 in worklib.bccu_xactor_pkg [package])
    File: /var/vob/timm/module/vob/units/bccu/source/sv/tb/bccu_tb/bccu_model/bccu_channel.sv, line 200, position 18
    Scope: worklib.bccu_xactor_pkg::bccu_channel@3958_3.run
    Source : linear_walk();
    Position: ^
    Native Code Stream (t=200008000000): Task run_phase (file: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_component.svh, line: 2301 in worklib.uvm_pkg [package])
    File: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_component.svh, line 2302, position 4
    Scope: worklib.uvm_pkg::uvm_component@3958_3.run_phase
    Source : run();
    Position: ^
    Native Code Stream (t=200008000000): Task exec_task (file: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_common_phases.svh, line: 255 in worklib.uvm_pkg [package])
    File: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_common_phases.svh, line 258, position 22
    Scope: worklib.uvm_pkg::uvm_run_phase::exec_task
    Source : comp_.run_phase(phase);
    Position: ^
    Native Code Stream (t=200008000000): Scope unmblk1 (file: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_task_phase.svh, line: 137 in worklib.uvm_pkg [package])
    File: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_task_phase.svh, line 145, position 16
    Scope: worklib.uvm_pkg::uvm_task_phase::execute.unmblk1
    Source : exec_task(comp,phase);
    Position: ^
    Native Code Stream (t=200008000000): Parallel block sub-process (file: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_task_phase.svh, line/pos: 137/10 in worklib.uvm_pkg [package])
    Verilog Syntax Tree: sequential block statement (VST_S_SEQ_BLOCK) in verilog_package worklib.uvm_pkg:sv (VST)
    File: /opt/INCISIV_10.20.030/CEN/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_task_phase.svh, line 137, position 10
    Scope: uvm_pkg::uvm_task_phase::execute.unmblk1
    Source : begin
    Position: ^
    csi-ncsim - CSI: investigation complete took 0.046 secs, send this file to Cadence Support
  • TAM1
    That looks like a bug and I think you'll need to report it to Cadence customer support. The lack of the verbose flag is the equivalent of a "keyword" to the $nc_mirror call. Once you have the "verbose" mode working to your satisfaction, you should be able to delete that string without making any other changes to your source.
  • damo1865
    Hi Tam1,
    Thanks again for the response. I will log this with cadence. Do you know of any other way to suppress these messages. Will the ncsim quiet switch (-q) facilitate this.
    dam01865
  • TAM1
    No, I don't know of any other way to turn off those messages.
