  2. Functional Verification
  3. Declaring array of uniquely parameterized classes
  • Subscribers 68
  • Views 17285
benbuchanan
benbuchanan over 14 years ago
In my SystemVerilog environment, I have an array of a class typefor which I need to customize instantiation parameters for each class in the array.  With all classes the same, I can do
 my_class #(.PARAM1(32), .PARAM2(8)) classes[8];
However, I can't figure out how to customize the PARAM1 and PARAM2 parameters for each specialization.  Is this possible?
  • umery
    umery over 14 years ago
    I don't believe it is legal to have different parameterizations for an array in SystemVerilog.
    You have atleast 2 options that come to mind:
    1) Use variables in classes that you can initialize, configure or constrain to different values to model different behavior.  I suspect that your params are affecting data types, value ranges, etc. so this may not be viable.
    2) Use different array identifiers to group classes with same parameters.
    Umer
  • benbuchanan
    I thought that might be the case.  The issue is that in my case the parameters control the data bus width of the associated interface, so that must be available at compile time.  I think I'll just need to split the affected class specializations out of the array.
    Ben
  • umery
    Precisely.  This is what I meant by option 2.  Split the array by class specializations.
    It would be a neat feature for the language to support heterogeneous types in an array and pass parameters in the constructor to allocate appropriate storage, but that’s not the case with SystemVerilog.
  • benbuchanan
    Thanks, and I agree.
