  2. Functional Verification
  3. Looking for help with System Verilog in AMS
  • Replies 12
  • Subscribers 66
  • Views 20160
JRAHildebrand
JRAHildebrand over 13 years ago
I've generated a netlist for a testcase and get the following error in the irun.log:
Elaborating the design hierarchy:
bias i_bias ( .ibias(ibias[3:0]), .vdd(vdd), .vss(vss), .en(en[0]));
ncelab: *E,CUINFI (./netlist.vams,39|41): An interface declaration must be connected to an interface (test_top.i_top).
   Analog vdd, vss;
ncelab: *E,CUIMBC (./development/SYS_VLOG_ANA_TEST/bias_verilog.sv,42|12): An interface port declaration must be connected (test_top.i_top.i_bias).
ncelab: *E,CUINFI (./netlist.vams,39|52): An interface declaration must be connected to an interface (test_top.i_top).
   Analog vdd, vss;
ncelab: *E,CUIMBC (./development/SYS_VLOG_ANA_TEST/bias_verilog.sv,42|17): An interface port declaration must be connected (test_top.i_top.i_bias).
That goes on for a while and there are a number of them.  So, the question is how do I connect the port declaration?  Here's the file referenced:
 import ADMS_signals_pkg::*;
module bias (
              vdd,
              vss,
              en,
              ibias
`include "parameters.svh"
   Analog vdd, vss;
   Analog ibias[3:0];
   input wire en;
   Amps                 iout[3:0];
   integer              vdd_ok;
   integer              vss_ok;
   integer              supplies_ok;
   event                started;
//   Driver vdd_d         = new(vdd);
//   Driver vss_d         = new(vss);
   ISource ibias_src[3:0];
   initial begin
      foreach (ibias_src[i])
        begin
           ibias_src[i]=new(ibias[i]);
        end
      @(en == 1'b1 && supplies_ok == TRUE);
      #100 -> started;
   end
//   Driver ibias_d = new(ibias[1]);
//   Driver ibias_d = new(ibias[2]);
//   Driver ibias_d = new(ibias[3]);
   always @(vdd.changed)
     begin
        if (vdd.v < VDD_MIN)
          vdd_ok = FALSE;
        else if (vdd.v > VDD_MAX)
          vdd_ok = FALSE;
        else
          vdd_ok = TRUE;
     end
   always @(vss.changed)
     begin
        if (vss.v < VSS_MIN)
          vss_ok = FALSE;
        else if (vss.v > VSS_MAX)
          vss_ok = FALSE;
        else
          vss_ok = TRUE;
     end
   always @(vdd_ok, vss_ok)
     begin
        if (vdd_ok == TRUE && vss_ok == TRUE)
          supplies_ok = TRUE;
        else
          supplies_ok = FALSE;
     end
   initial iout[0] = -IBIAS_TYP;
   initial iout[1] = -IBIAS_TYP;
   initial iout[2] = -IBIAS_TYP;
   initial iout[3] = -IBIAS_TYP;
   always @(started,en)
     begin
          if ( en==1'b1 && supplies_ok==TRUE)
            ibias_src[i].seti(iout[i]);
          else
            ibias_src[i].seti(0.0);
     end
endmodule // bias
  • Shalom B
    Shalom B over 13 years ago
    At least part of the problem is that when irun reads a file that it identifies as an SV file by its extension, like bias_verilog.sv, then when it sees a type that is undefined from its point of view, such as "analog", it assumes that it is an interface type, which is not the case here, and then it gets all confused.
     Shalom
  • JRAHildebrand
    I do have an include file which gets included when it creates the netlist.sv called ADMS_signals_pkg.sv.  Since the bias_verilog.sv is included (with the -v in the AMS Options form) the definition for the bias module is in the netlist.sv, too.  So it should get the Analog definition.  Or am I doing something wrong with that kind of setup?
    In ADMS_signals_pkg.sv I have the following:
      // Parent class for Analog connections
      virtual class Connections ;  // Connections to Analog nets
        virtual interface Analog ownerNet;
        protected Amps inet;     // Branch current from the net
        function new(virtual Analog owner = null);
          ownerNet = owner;
        endfunction
        task set() ; // Sets connection values and then calls net resolution
        endtask
        virtual function Amps getinet() ; // Get net branch current
        endfunction
        function Watts power() ; // get power disipated(-) or sourced(+) from the connection
          return ownerNet.v*inet ;
        endfunction
      endclass : Connections
  • tpylant
    tpylant over 13 years ago
    It would be helpful to see the top of the log file that shows all the options being passed to irun.
    Tim
  • JRAHildebrand
    Thanks for all the help, guys.  Here's the head of the irun.log:
    irun: 11.10-s062: (c) Copyright 1995-2012 Cadence Design Systems, Inc.
    TOOL: irun 11.10-s062: Started on Sep 11, 2012 at 09:30:37 PDT
    irun
    -f irunArgs
    -UNBUFFERED
    -errormax 50
    -status
    -nowarn DLNOHV
    -sysv_ext .sv
    -v93
    -incdir ./development/SYS_VLOG_ANA_TEST/sv_resolution/
    -timescale 1ns/1ns
    -vtimescale 1ns/1ns
    -discipline logic
    -delay_mode None
    -novitalaccl
    -access r
    -noparamerr
    -amspartinfo ../psf/partition.info
    -modelincdir ./development/SYS_VLOG_ANA_TEST/sv_resolution/
    -analogcontrol ./amsControlSpectre.scs
    -input ./probe.tcl
    -run
    -exit
    -ncsimargs "+amsrawdir ../psf"
    -simcompatible_ams spectre
    -name test_top:config
    ./netlist.vams
    -f ./textInputs
    ./development/SYS_VLOG_ANA_TEST/sv_resolution/test_system_verilog/vga/systemVerilog/verilog.sv
    ./development/SYS_VLOG_ANA_TEST/sv_resolution/test_system_verilog/dig/systemVerilog/verilog.sv
    ./development/SYS_VLOG_ANA_TEST/sv_resolution/test_system_verilog/dac/systemVerilog/verilog.sv
    ./development/SYS_VLOG_ANA_TEST/sv_resolution/test_system_verilog/vco/systemVerilog/verilog.sv
    ./development/SYS_VLOG_ANA_TEST/sv_resolution/test_system_verilog/adc/systemVerilog/verilog.sv
    ./development/SYS_VLOG_ANA_TEST/sv_resolution/test_system_verilog/stim/systemVerilog/verilog.sv
    ./development/SYS_VLOG_ANA_TEST/sv_resolution/test_system_verilog/source/systemVerilog/verilog.sv
    -v ./development/SYS_VLOG_ANA_TEST/bias_verilog.sv
    ./cds_globals.vams
    -l ../psf/irun.log
    file: ./development/SYS_VLOG_ANA_TEST/bias_verilog.sv
    package bias_verilog.ADMS_signals_pkg:sv
    errors: 0, warnings: 0
  • tpylant
    Try taking off the '-v' and just call out the file directly.
    Tim
  • JRAHildebrand
    I don't put the -v in, ADE appears to do that when I hit the netlist and run button.
    The file is added via the "Library Files" line in the ADE-L -> Simulation -> Options -> AMS Simulator
    The bias_verilog.sv file is just one that gives me the error, too.  Others listed in the -f also give the same problem (vga, dac, vco, adc, source specifically).
  • Shalom B
    Where is the type 'Analog' (with uppercase A) declared?
    Shalom
  • JRAHildebrand
    In an included file.  Here's the top of the file with the Analog portion.
    package ADMS_signals_pkg;
      typedef enum {x,ok} Astatus ;
      typedef real Volts;
      typedef real Amps;
      typedef real Ohms;
      typedef real Mhos;
      typedef real Watts;
      parameter Ohms open_circuit = 1.0e100;
      // unit multipliers
      `define u *1e-6  //micro
      `define m *1e-3  //milli
      `define n *1e-9  //nano
      `define p *1e-12 //pico
      `define f *1e-15 //femto
      `define K *1e+3  //kilo
      `define M *1e+6  //mega
      `define G *1e+9  //giga
          ownerNet = owner;
        endfunction
        endtask
        endfunction
        endfunction
  • JRAHildebrand
    I updated my version of Incisiv from 11.10.062 to 12.10.005. It gave better error messages and now I can get through compilation but it still generates errors in Elaboration. Here is a piece of the irun.log:
    bias i_bias ( .vdd(vdd), .vss(vss), .en(en[0]), .ibias(ibias) );
    ncelab: *E,CUINFI (./simulation/test_top/ams/config/netlist/netlist.vams,39|21): An interface declaration must be connected to an interface (test_top.i_top).
    Analog vdd, vss;
    ncelab: *E,CUIMBC (../bias_verilog.sv,42|12): An interface port declaration must be connected (test_top.i_top.i_bias).
    All the errors seem to be with the vdd, vss, ibias which are declared Analog (as per the previous post I did with the section where it has the interface declaration). Here is now the netlist.ams calls this block:
    So again I'm stumped as to why it appears to be connected and the elaboration says it's not. Jeff
  • Shalom B
    I still did not see a declaration of the type Analog.
     All I saw were virtual interface declarations using Analog as the interface type.
     That already implies implies that Analog is an interface type.
    Shalom
