  2. Functional Verification
  3. Failure of liveness property
  • Subscribers 67
  • Views 16167
Wesh
Wesh over 13 years ago
Hi everybody
I'm trying to verify the following property:
-- psl assert_p1: assert always ( (CS = st_idle) -> next eventually! ((CS = st_get_ack) or (CS = st_set_ack)) );
The section "Waveforms for Liveness Assertions" of chapter 9 on the document Formal Verifier User Guide says: "A failed liveness assertion has an associated counter-example in which there is an infinitely repeating sequence of non-satisfying states for the assertion." And this is exactly what the problem is. The property fails and the counter-example has a LoopMarker. I suppose I have to force IFV to verify for more time?
The DUT is a state machine implementation in which CS is a user-defined type signal representing the current state and st_idle, st_get_ack, st_set_ack, etc are states of the state machine. st_idle has a transition for itself until it matches a value for three different signals. The VHDL code of this behaviour is the following:
when st_idle =>
    if ready_i = '1' and busy_s = '0' then
        NS      <= st_get_ack;
    elsif ready_frame_i = '1' then
        NS      <= st_set_ack;
    else
        NS      <= st_idle;The property above checks if
It's interesting that a property checking if states st_set_ack and st_get_ack are never achieved and failed as well:
-- psl assert_pn1: assert never ( (CS = st_get_ack) or (CS = st_set_ack) );
What can I do?
  • StephenH
    StephenH over 13 years ago
    This is normal. You must also specify a fairness property (constraint) that tells the tool to eventually assert whatever input the design is waiting for. In you case I guess that's either ready_i or ready_frame_i, if those are the correct primary inputs.
    -- psl assume always ( eventually! (ready_i ='1' or ready_frame_i = '1') );
  • TAM1
    TAM1 over 13 years ago
     It sounds like the tool is working as it should. For a property to fail, it only takes a single example in which it turns out to be untrue, no matter how many other scenarios exist in which it is true. From the code you've shown, if ready_frame never goes high and if ready_i and busy_s never take on the correct states, the state machine will stay in the idle state forever.
    Usually you need a kind of condition called a "fairness constraint" to ensure that a liveness property does not get stuck in an infinite loop waiting for something to occur. A fairness constraint says that something will occur eventually if you wait long enough. For your example, you may need to add a constraint such as:
    -- psl ready_frame_fairness: assume always ( eventually! (ready_frame = '1') );
