  2. Functional Verification
  3. files required to use vams netlist
  • Subscribers 68
  • Views 18060
Visbi
Visbi over 13 years ago
Hi All,
I am new to mixed singal verifcation. I want to run mixed signal verifcation using irun. I grabbed the verilog modules and replace some of verilog modules with veriog A and some with cadence schematic. Then I created the netlist.vams of whole design using ADE-L (AMS simulator).
Since digital team is using ncsim to verify funcationality, I would like to use the same environment and test benches by just replacing entire verilog modules to single netlist.vams file.
Can anybody provide me step by step help for this?
-Thanks in advance.
  • shalem7
    shalem7 over 13 years ago +1
    Hi, Visbi said: I grabbed the verilog modules and replace some of verilog modules with veriog A and some with cadence schematic I hope you included disciplines.vams file in your verilog-A module. To run…
  • shalem7
    To run the simulation We need,
    -> analog control file which specifies the type of analysis,time,simulator options etc.
        Ex: tran tran stop=3.5m
      We can pass this file through command line.
      irun *.vams -analogcontrol sim_control.scs
     I hope this helps.
    Shalem
