  2. Functional Verification
  3. Connecting VHDL port to system verilog interface definition...
  • Subscribers 67
  • Views 18335
Connecting VHDL port to system verilog interface definition in UVM
sunil kr
sunil kr over 11 years ago
I have a package definition in VHDL which contains the user defined array type which is the output of my DUT.The definition is as below:
TYPE loop_reg_ty IS RECORD
      loop_index_value    : std_logic_vector(REG_BITWIDTH-1 DOWNTO 0);
      loop_counter : std_logic_vector(REG_BITWIDTH-1 DOWNTO 0);
      loop_end_flag : std_logic;
END RECORD;
TYPE loop_array_ty is array (MAX_NO_OF_LOOPS-1 downto 0) of std_logic_vector(REG_BITWIDTH-1 downto 0);
I read in other posts that cadence doesn't support importing the package into system verilog environment and hence i am trying to define the similar structure in system verilog environment as below :
typedef struct packed {
                            bit [REG_BITWIDTH-1:0] loop_index_value;
                            bit [REG_BITWIDTH-1:0] loop_counter;
                            bit loop_end_flag;
                          } raccu_loop_reg_ty;
typedef loop_reg_ty [MAX_NO_OF_RACCU_LOOPS-1:0] loop_array_ty;
But during elaboration i am getting the error as below :
ncelab: *E,CFMPTC  : VHDL port type is not compatible with Verilog.
Please let me know the possible work around solution for this.
  • StephenH
    StephenH over 11 years ago
    Those others posts are a bit out of date; we started supporting import of VHDL packages to SV in the Incisive 14.1 release.
    Not all data types are supported, but the common / standard ones are OK.
    I don't have the details to hand, so I can't recall whether struct-to-record port connections are supported yet. You may need to file a support ticket to get the full and current information.
  • sunil kr
    Hello Stephen, Thanks for your early response. I am having Incisive version 14.10-s004 . I will try try to contact through support ticket.
  • sunil kr
    Can you please provide the link where i can contact the support ticket system.
  • StephenH
    http://support.cadence.com/
