  2. Functional Verification
  3. Practical guide to integrate Specman with a ISS
  • Subscribers 66
  • Views 5760
FormerMember
FormerMember over 11 years ago
I recently developed an Instruction Set Simulator using an Architecture Description Language called ArchC.
My plan is to port this ISS into Cadence's tools for further Embedded Software Verification.
It seems a good idea, however I'm facing serious problems to integrate the ISS with Specman.
I was wondering if is there a practical guide, or examples with an ISS written in SystemC?
I tried to use the IVB to create the project files, but it seems so complicated, I'm looking for a simple example
that uses an ISS in SystemC. (All the examples in the documentation either use Verilog or Host code Execution)
Thank you.
  • hannes
    hannes over 11 years ago
    We do not have an examples or practical guide to integrate an ISS into Specman. However, the SystemC interface has been around for some time and is used by a large number of customers. We support access via TLM1 and TLM2 interfaces, method ports and simple ports (for variables and sc_signals). All of this is documented in the integrators guide. What specific issues are you running into?
  • FormerMember
    I'm kind lost actually. How to compile the software, what e files have to be called by simulation, how do I connect the SystemC simulator event with the e code? I found the documentation very difficult to follow, would be nice a more practical guide. Thanks anyway.
