  2. Functional Verification
  3. e generation question
  • Subscribers 67
  • Views 14778
myonlyscreen
myonlyscreen over 11 years ago
the next code used to work in IES 13.2 but results in error in 14.2.
var idx : uint[0..7];
var num : byte = 0xA;
gen idx keeping {read_only(num[it:it] == 0);};
I am getting the next error message:
GEN_NO_GENERATABLE_NOTIF
Why ?
How should I rewirte this to do the same functionality, without converting the var num into a list ?
Thanks.
  • hannes
    hannes over 11 years ago
    there are 2 things to consider:
    1) you put the read_only around "num" and "it", so both are read_only, and nothing is generated
          - this is why you get the GEN_NO_GENERATABLE_NOTIF error
          - you can change that to "read_only(num)[it:it]== ...."
    2) to enable generative list indexing, you need to do the following before loading this code:
         set_config(gen,use_generative_slice_indices,TRUE)
    Once you've made both changes it will work as desired in 14.2
    -hannes
