  2. Functional Verification
  3. Forcing Verilog signal simple_port with pli_access == TRUE...
  • Subscribers 67
  • Views 19002
Forcing Verilog signal simple_port with pli_access == TRUE in Specman
mjzintc
mjzintc over 11 years ago
I am working in Specman e and I am trying to force a signal value to a simple port that has its pli_access constrained to TRUE. I am unable to remove the pli_access constraint.
If I use the force keyword, I get a specman error message telling me that force is unsupported with pli_access set to TRUE. Unfortunately, I cannot just do a normal assign because I need the value of this signal to remain until I explicitly release it later.
All of my work arounds don't seem to work. I may need to operate on a signal that is wider than 32 bits as well...
Thanks for your time.
  • hannes
    hannes over 11 years ago
    Hi Michael,
    you can use a simple indexed_port (without any index) to access a signal/wire. For those the combination of pli_access() and force/release is supported. This is documented in the Specman Integrators guide under:
    6.4.6 Forcing and Releasing SystemVerilog Objects Accessed with e Simple Indexed Ports
    -hannes
  • mjzintc
    Hi Hannes,
    Thanks for the response. I am aware of the unsupported combination, but I still need to force a signal that has pli_access() set to TRUE. Maybe I am misunderstanding what pli_access() does... Are there any workarounds or constructs that specman provides for anyone who has this specific use case of needing to force a signal while pli_access() is TRUE?
    Michael
  • hannes
    Hi Michael,
    maybe there was a misunderstanding, but what I wrote in the last mail is a viable workaround. The combination of indexed_port with the pli_access attribute and the use of force/release is supported and this enables you to force a signal.
    Maybe some example code would help:
    <' // t1.e
    method_type w_pli();
    extend sys {
      wp: simple_port (w_pli) of int is instance;
      keep wp.pli_access()==TRUE;
      keep wp.hdl_path() == "~/top/wp";
      clk_rise: in event_port is instance;
      keep clk_rise.hdl_path() == "~/top/clk";
      keep clk_rise.edge() == rise;
      run() is also {
        start tcm();
      tcm()@clk_rise$ is {
        while TRUE {
          if (sys.time > 500) {
            stop_run();
          if (sys.time == 250 ) {
            force wp.index()$=55;
          if (sys.time == 450 ) {
            release wp.index();
          wait [2];
    ---- ex.v----
    module top;
      wire [31:0] wp;
      reg clk;
      initial clk = 0;
      always #50 clk = ~clk;
    endmodule
    -hannes
  • mjzintc
    Oh I see. Yeah, I did misread your last post. This is exactly the workaround I'm looking for. Thanks!
