  2. Functional Verification
  3. Reg: generating a .vsif file before running a regression...
  • Subscribers 67
  • Views 24545
Reg: generating a .vsif file before running a regression in vManager 15.10
Shobith
Shobith over 10 years ago
We are trying to understand the vManager tool and here are the some doubts we are stuck with:
1. How do we create a .vsif file to run a regression in the vManager tool?
2. How to link the spec, verification plan, and the test case. What we have figured out is how to generate a vplan with respect to the specification document. But, How do we link already generated vplan with the .vsif file and run a regression in vManager?
Thank you in advance.
Shobith E.
  • StephenH
    StephenH over 10 years ago
    Have you found the Rapid Adoption Kits on support.cadence.com? These have all the info you need to quickly get started using vManager and vPlans... Look for the MDV/Coverage RAK on this page (you'll need to log in to the support site first)... http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ProductInformation/Functional_Verification/Incisive_RAKs/Incisive_RAK.htm
  • Shobith
    Hello Stephen,
    Thanks for the tip.
    The issue I am facing now is:
    In the.vsif file, inside the test block, when I mention seed/sv_seed and give them one_value/multiple_values, the irun command (in run_script) is ignoring them and generating a random seed. How can I force multiple seeds to be taken for the same test multiple time. At present, I am creating multiple test blocks, each with different seed value (given with the irun commands -seed option) to run the regression.
    PS: The value of count inside the test block is equal to the number of different seeds.
    Shobith Edayath
  • StephenH
    Hi Shobith.
    The attributes like sv_seed get copied into environment variables that you can use inside your run_script. For the seed, you have $BRUN_SV_SEED, and this would be used in your run_script as:
    irun -R -svseed $BRUN_SV_SEED
