  2. Functional Verification
  3. forcing signal to hierarchical connection in SystemVerilog...
  • Subscribers 66
  • Views 19524
forcing signal to hierarchical connection in SystemVerilog when in interactive mode
Almendrico
Almendrico over 9 years ago
Hi Cadence, all
I know it is possible to do hierarchical assigns/forces from the testbench. e.g:
assign clk   = chip_top.digital_core.some_clock;
I would like to do this kind of stuff from the ncsim interactive console. Can you please advice whether this is supported by ncsim and, if it is not, why ?
  • TAM1
    TAM1 over 9 years ago
    First, you need to have "write" access turned on when you elaborate your design.
    irun -accesss w ...
    Then you can use the TCL commands "deposit" and "force" to put values on internal wires and variables in the design. Look them up in the docs to see how the commands differ and what their options are.
  • Almendrico
    Hi TAM1,
    I should probably have explained better. I am familiar with what these commands do, and I am running with +rwc access. Problem is that ncsim does not like hierarchical references on the RHS of the assignment. I think it has to do with the fact that the hierarchical references are resolved at elaboration time, so they do not work in the TCL interactive console. Stuff like this can be done from the tcl console:
    force chip_top.digital_top.clk = 1'b0;
    But this does not work:
    force chip_top.digital_top.clk = tb.clk;
    (while it works if it is done inside an initial block in the testbench)
  • TAM1
    Well, this will do it. But it's really only a stop-gap. Coding the connection in the HDL will be much more efficient.
    stop -object top.sys_clk -exec {force top.t1.clk #top.sys_clk} -silent -continue
  • Almendrico
    wow! That was hacky!
