  2. Functional Verification
  3. compare VerilogA result with SystemVerilog result
  • Subscribers 68
  • Views 15513
NE555
NE555 over 10 years ago
Hi to everyone.
I made my circuit in verilogA with the code and circuit part. The simulation is very slow, so I made the systemverilog model.
Now I would compare the results. In some Cadence slide I saw that this is possible:
These are my results:
My question is: Was the image found in the Cadence slide a result of photoshop or is there a function in virtuoso or simvision to compare two results?
If is there this function, how it work?
Thank you very much
L.F.
  • cmarqu42
    cmarqu42 over 10 years ago
    Hi Luigi,
    I believe what you are seeing can be done by selecting two or more signals in the wavetrace, right-clicking on their names, then  "Create > Analog Overlay".
    You can even do this for digital signals when you set "Trace Type" to "Analog / ..." before.
    HTH
      Colin
  • NE555
    Thank you very much :)
