  2. Functional Verification
  3. I am checking the code coverage for one of my Module's testbench...
  • Subscribers 67
  • Views 4742
I am checking the code coverage for one of my Module's testbench, but the expression coverage is appearing as "n/a" , why is that so ? there are if-else & assignments in the RTL... how do I enable it ?
Saru K S
Saru K S over 10 years ago
  • StephenH
    StephenH over 10 years ago
    It would help if you told us what coverage scoring options you used at elaboration time.
    If you used "irun -coverage ALL", or instead of "ALL" you had a string like "B:E" (E means expression) then you should expect to see coverage. That assumes you haven't passed the "-covdut" option to control which module is treated as the top level for coverage.
    However if you used "irun -covfile my_coverage_file.ccf" then it really depends on what control commands are inside the my_coverage_file.ccf.
  • Saru K S
    Hello Stephan,
                I am using the following options in my run command :
    "set compileOptionsTb            = -nocopyright -errormax 1 -linedebug \
                                      -messages \
                                      -COVERAGE all -covdut <dut-name> -covfile <naME.covfile>"
    And, my covfile is as follows :
    select_coverage -all
    set_expr_scoring -all
    set_assign_scoring
    set_libcell_scoring
    set_fsm_scoring -hold_transition
    set_fsm_arc_scoring -on
    set_branch_scoring
    set_explicit_block_scoring -off -case
    set_ignore_library_name
    in spite of that, even though I have expressions in my dut, I cannot see them in the IMC.
    Thanks in advance.
    Saraswati
  • Saru K S
    Can anybody help me out in this ?
  • StephenH
    I think it would be best if you can contact the Cadence support team via support@cadence.com or on the website  so that someone local to you can get in touch to look at this with you, either in person or by Webex.
