  2. Functional Verification
  3. Including `defines with ncvlog netlisting
  • Subscribers 67
  • Views 18474
casparvv
casparvv over 10 years ago
All,
This is using IC6.1.7-64b.500.6. I have a mixed-signal hierarchy in which several of the blocks have both schematic and Verilog cellviews. The Verilog cellviews are purely digital representations of analog / mixed-signal circuit behavior. I'm using a file with some define statements to govern this behavior. For example, there is a module that does this:
    always @ (posedge in) begin
        #(`TIME_RUN_ADC);
        out = 1;
    end
in which TIME_RUN_ADC is defined elsewhere, in a file that gets included in the digital / ams simulations.
When I modify the code in the Cadence text editor and try to extract connectivity, it warns that the variable is not recognized (*E,NOTDIR). I've tried to edit the hdl.var to include -NOWARN NOTDIR, but then ncvlog reports that this error cannot be surpressed. I've also tried using -INCDIR to the directory that holds a file with the defines, but ncvlog still did not find them. Editing hdl.var to include -DEFINE TIME_RUN_ADC=xx works, but there are many different modeling constants throughout the chip that would produce a long list if defined in this way. Is there a way to pass a list of defines to ncvlog? Thanks in advance!
Best regards,
Caspar
  • StephenH
    StephenH over 10 years ago
    You cannot suppress an error for a missing symbol!
    I'm guessing that something about the way you're compiling the files is causing the `define to not be in context when this Verilog file gets compiled.
    You might try adding "-parseinfo include" to the irun command so that you see all the `include files that are being read in, this might give you a clue as to whether the right files are present in the exact ncvlog step that is reporting the error.
    You could brute-force it by adding +define+TIME_RUN_ADC=<your_value_goes_here> to the irun command, but that's probably just masking other problems with your flow. Better to root cause the current problem and fix it.
  • casparvv
    Hi Steve,
    Thanks for your response. Perhaps I was unclear, the problem occurs after editing the code, not at compilation -- there I can include the 'defines.v' file and everything works fine (of course, during the sim, not having missing symbols is pretty important..). What I would like is a way to include the same 'define.v' with the process that extracts the Verilog from the text editor, i.e. when teSaveAndExtract() runs. So far, I've edited the hdl.var with some '-define AA=0' statements, but as you say, this is brute force and not scalable. My best bet was to use the -INCDIR statement in the same hdl.var, but that doesn't seem to work, or I'm not configuring it properly. Do you have any other ideas? Thanks!
    Caspar
